Surgical Process Mining with Test and Flip Net Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Surgical process modeling aims at providing an explicit representation of surgical procedural knowledge. Surgical process models are inferred from a set of surgical procedure recordings, and represent in a concise manner concurrency, causality and conflict relations between actions. The paper presents preliminary results regarding the use of test and flip nets, a mild extension of flip-flop nets, to represent surgical process models. A test and flip net synthesis algorithm, based on linear algebraic methods in the Z/2Z ring is detailed. Experimental results regarding the use of this synthesis algorithm to automate the construction of simple surgical process models are also presented.
Autre [cs.OH]
caillaud-art13.pdf (274.27 Ko) Télécharger le fichier
hal-00872284 , version 1 (11-10-2013)
  • HAL Id : hal-00872284 , version 1
Benoît Caillaud. Surgical Process Mining with Test and Flip Net Synthesis. Application of Region Theory (ART), Jul 2013, Barcelona, Spain. pp.43-54. ⟨hal-00872284⟩
483 Consultations
262 Téléchargements
