Reports
Evaluating Trace Aggregation Through Entropy Measures for Optimal Performance Visualization of Large Distributed Systems
Robin Lamarche-Perrin 1 Lucas Schnorr 2 Yves Demazeau 1 Jean-Marc Vincent 3
1 MAGMA - Modélisation d’agents autonomes en univers multi-agents
LIG - Laboratoire d'Informatique de Grenoble
3 MESCAL - Middleware efficiently scalable
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : Large-scale distributed high-performance applications are involving an ever-increasing number of threads to explore the extreme concurrency of today's systems. The performance analysis through visualization techniques usually su ers severe semantic limitations due, from one side, to the size of parallel applications, from another side, to the challenges to visualize large-scale traces. Most of performance visualization tools rely therefore on data aggregation in order to be able to scale. Even if this technique is frequently used, to the best of our knowledge, there has not been any real attempt to evaluate the quality of aggregated data for visualization. This paper presents an approach which lls this gap. We propose to build optimized macroscopic visualizations using measures inherited from information theory, and in particular the Kullback-Leibler divergence. These measures are used to estimate the complexity reduced and the information lost during any given data aggregation. We rst illustrate the applicability of our approach by exploiting these two measures in the analysis of work stealing traces using squari ed treemaps. We then report the e ective scalability of our approach by visualizing known anomalies in a synthetic trace le with the behavior of one million processes, with encouraging results.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00872483
Contributor : Arnaud Legrand Connect in order to contact the contributor
Submitted on : Tuesday, February 18, 2014 - 4:54:37 PM
Last modification on : Wednesday, July 6, 2022 - 4:17:23 AM
Long-term archiving on: : Sunday, May 18, 2014 - 10:36:21 AM
File
RR-LIG-037_orig.pdf
Identifiers
  • HAL Id : hal-00872483, version 1
Citation
Robin Lamarche-Perrin, Lucas Schnorr, Yves Demazeau, Jean-Marc Vincent. Evaluating Trace Aggregation Through Entropy Measures for Optimal Performance Visualization of Large Distributed Systems. [Research Report] RR-LIG-037, 2013, pp.21. ⟨hal-00872483⟩
Share
Metrics
Record views
623
Files downloads
240
