Numerical Simulations of Air???Sea Interaction under High Wind Conditions Using a Coupled Model: A Study of Hurricane Development, Monthly Weather Review, vol.128, issue.7, pp.2190-2210, 2000. ,
DOI : 10.1175/1520-0493(2000)128<2190:NSOASI>2.0.CO;2
Numerical simulations of tropical cyclone-ocean interaction with a high-resolution coupled model, Journal of Geophysical Research, vol.87, issue.D12, pp.23245-23263, 1993. ,
DOI : 10.1029/93JD02370
From short-range barotropic modelling to extended-range global weather prediction: a 40-year perspective, Tellus B: Chemical and Physical Meteorology, vol.113, issue.1, pp.13-32, 1999. ,
DOI : 10.3402/tellusa.v33i1.10692
Nesting Ocean Models, An Integrated View of Oceanography: Ocean Weather Forecasting in the 21st Century, 2006. ,
DOI : 10.1007/1-4020-4028-8_5
URL : https://hal.archives-ouvertes.fr/inria-00187576
The ncar csm flux coupler, 1996. ,
Local multiplicative schwarz algorithms for steady and unsteady convection-diffusion equations, East-West J. Numer. Math, vol.6, pp.27-41, 1998. ,
Comparison of different numerical methods used to handle the open boundary of a regional ocean circulation model of the Bay of Biscay, Ocean Modelling, vol.25, issue.1-2, pp.1-16, 2008. ,
DOI : 10.1016/j.ocemod.2008.05.009
URL : https://hal.archives-ouvertes.fr/hal-00387446
Eddies in easternboundary subtropical upwelling systems Ocean Modeling in an Eddying Regime, p.350, 2008. ,
Heat balance and eddies in the Peru-Chile current system, Climate Dynamics, vol.40, issue.1, pp.509-529, 2012. ,
DOI : 10.1007/s00382-011-1170-6
URL : https://hal.archives-ouvertes.fr/hal-00758325
Diurnal Coupling in the Tropical Oceans of CCSM3, Journal of Climate, vol.19, issue.11, pp.2347-2365, 2006. ,
DOI : 10.1175/JCLI3739.1
On the Schwarz Alternating Method for Oceanic Models on Parallel Computers, Journal of Computational Physics, vol.141, issue.2, pp.93-111, 1998. ,
DOI : 10.1006/jcph.1998.5898
Flux-gradient relationships in the constant flux layer, Quarterly Journal of the Royal Meteorological Society, vol.96, issue.410, pp.715-721, 1970. ,
DOI : 10.1002/qj.49709641012
Bulk Parameterization of Air???Sea Fluxes: Updates and Verification for the COARE Algorithm, Journal of Climate, vol.16, issue.4, pp.571-591, 2003. ,
DOI : 10.1175/1520-0442(2003)016<0571:BPOASF>2.0.CO;2
Schwarz methods over the course of time, Electron. Trans. Numer. Anal, vol.31, pp.228-255, 2008. ,
Optimized Schwarz Waveform Relaxation Methods for Advection Reaction Diffusion Problems, SIAM Journal on Numerical Analysis, vol.45, issue.2, pp.666-697, 2007. ,
DOI : 10.1137/050642137
Sensitivity of Simulated Tropical Cyclone Structure and Intensity to Horizontal Resolution, Monthly Weather Review, vol.138, issue.3, pp.688-704, 2009. ,
DOI : 10.1175/2009MWR2976.1
The architecture of the earth system modeling framework, Computing in Science & Engineering, vol.6, issue.1, pp.18-28, 2004. ,
DOI : 10.1109/MCISE.2004.1255817
Analysis of Idealized Tropical Cyclone Simulations Using the Weather Research and Forecasting Model: Sensitivity to Turbulence Parameterization and Grid Spacing, Monthly Weather Review, vol.137, issue.2, pp.745-765, 2009. ,
DOI : 10.1175/2008MWR2220.1
A New Vertical Diffusion Package with an Explicit Treatment of Entrainment Processes, Monthly Weather Review, vol.134, issue.9, pp.2318-2341, 2006. ,
DOI : 10.1175/MWR3199.1
MpCCI???a tool for the simulation of coupled applications, Concurrency and Computation: Practice and Experience, vol.101, issue.2, pp.183-192, 2006. ,
DOI : 10.1002/cpe.913
Mesoscale Simulation of Tropical Cyclones in the South Pacific: Climatology and Interannual Variability, Journal of Climate, vol.24, issue.1, pp.3-25, 2011. ,
DOI : 10.1175/2010JCLI3559.1
URL : https://hal.archives-ouvertes.fr/hal-00755135
Ocean feedback to tropical cyclones: climatology and processes, Climate Dynamics, vol.64, issue.4, pp.1-24, 2014. ,
DOI : 10.1007/s00382-014-2096-6
URL : https://hal.archives-ouvertes.fr/hal-01021621
Impact of Tropical Cyclones on the Heat Budget of the South Pacific Ocean, Journal of Physical Oceanography, vol.42, issue.11, pp.1882-1906, 2012. ,
DOI : 10.1175/JPO-D-11-0133.1
URL : https://hal.archives-ouvertes.fr/hal-00766583
Surface Fluxes for Practitioners of Global Ocean Data Assimilation, An Integrated View of Oceanography: Ocean Weather Forecasting in the 21st Century, 2006. ,
DOI : 10.1007/1-4020-4028-8_9
Attribution and Impacts of Upper-Ocean Biases in CCSM3, Journal of Climate, vol.19, issue.11, pp.2325-2346, 2006. ,
DOI : 10.1175/JCLI3740.1
Oceanic vertical mixing: A review and a model with a nonlocal boundary layer parameterization, Reviews of Geophysics, vol.33, issue.11, pp.363-403, 1994. ,
DOI : 10.1029/94RG01872
Sensitivity of three mediterranean heavy rain events to two different sea surface fluxes parameterizations in high-resolution numerical modeling, J. Geophys. Res, vol.113, 2008. ,
URL : https://hal.archives-ouvertes.fr/meteo-00337123
Effects of the air-sea coupling time frequency on the ocean response during mediterranean intense events. Ocean Dyn, pp.539-549, 2009. ,
URL : https://hal.archives-ouvertes.fr/meteo-00396953
Algorithmes de Schwarz et couplage océan-atmosphère, Thesis (Ph.D.)? Grenoble University (France), 2008. ,
Optimal Control of the Convergence Rate of Schwarz Waveform Relaxation Algorithms, Lecture Notes in Computational Science and Engineering, vol.91, pp.599-606, 2013. ,
DOI : 10.1007/978-3-642-35275-1_71
Toward an optimized global-in-time schwarz algorithm for diffusion equations with discontinuous and spatially variable coefficients, part 1 : the constant coefficients case, Electron. Trans. Numer. Anal, vol.40, pp.148-169, 2013. ,
Toward an optimized global-in-time schwarz algorithm for diffusion equations with discontinuous and spatially variable coefficients, part 2 : the variable coefficients case, Electron. Trans. Numer. Anal, vol.40, pp.170-186, 2013. ,
Are There Inescapable Issues Prohibiting the use of Terrain-Following Coordinates in Climate Models ? Ocean Modell, pp.57-79, 2012. ,
Mathematical theory for the coupled atmosphere-ocean models, J. Math. Pures Appl, vol.74, pp.105-163, 1995. ,
Spurious diapycnal mixing in terrain-following coordinate models: The problem and a solution, Ocean Modelling, vol.26, issue.3-4, pp.3-4, 2009. ,
DOI : 10.1016/j.ocemod.2008.09.004
URL : https://hal.archives-ouvertes.fr/hal-00409317
Equilibrium Structure and Dynamics of the California Current System, Journal of Physical Oceanography, vol.33, issue.4, pp.753-783, 2003. ,
DOI : 10.1175/1520-0485(2003)33<753:ESADOT>2.0.CO;2
Impact of intra-daily SST variability on ENSO characteristics in a coupled model, Climate Dynamics, vol.11, issue.2, pp.3-4, 2012. ,
DOI : 10.1007/s00382-011-1247-2
URL : https://hal.archives-ouvertes.fr/hal-01323617
Irreducible imprecision in atmospheric and oceanic simulations, Proc. Natl. Acad. Sci, pp.8709-8713, 2007. ,
DOI : 10.1073/pnas.0702971104
High-resolution atmospheric forcing for regional oceanic model: the Iroise Sea, Ocean Dynamics, vol.130, issue.2088, pp.375-400, 2007. ,
DOI : 10.1007/s10236-007-0115-4
URL : https://hal.archives-ouvertes.fr/hal-00172854
The Mathematical Representation of Wind Speed and Temperature Profiles in the Unstable Atmospheric Surface Layer, Journal of Applied Meteorology, vol.9, issue.6, pp.857-861, 1970. ,
DOI : 10.1175/1520-0450(1970)009<0857:TMROWS>2.0.CO;2
Software tools for pre- and post-processing of oceanic regional simulations, Environmental Modelling & Software, vol.23, issue.5, pp.660-662, 2008. ,
DOI : 10.1016/j.envsoft.2007.07.004
URL : https://hal.archives-ouvertes.fr/hal-00388202
Numerical Simulation of Air???Sea Coupling during Coastal Upwelling, Journal of Physical Oceanography, vol.37, issue.8, pp.37-2081, 2007. ,
DOI : 10.1175/JPO3104.1
Large sensitivity to initial conditions in seasonal predictions with a coupled ocean-atmosphere general circulation model, Geophysical Research Letters, vol.125, issue.8, 2002. ,
DOI : 10.1029/2000GL012710
OASIS4 ??? a coupling software for next generation earth system modelling, Geoscientific Model Development, vol.3, issue.1, pp.87-104, 2010. ,
DOI : 10.5194/gmd-3-87-2010
The Present and Future of the West African Monsoon: A Process-Oriented Assessment of CMIP5 Simulations along the AMMA Transect, Journal of Climate, vol.26, issue.17, 2013. ,
DOI : 10.1175/JCLI-D-12-00505.1
URL : https://hal.archives-ouvertes.fr/hal-01109027
Climate Drift in the CMIP5 Models*, Journal of Climate, vol.26, issue.21, pp.8597-8615, 2013. ,
DOI : 10.1175/JCLI-D-12-00521.s1
The regional oceanic modeling system (ROMS): a split-explicit, free-surface, topography-following-coordinate oceanic model, Ocean Modelling, vol.9, issue.4, pp.347-404, 2005. ,
DOI : 10.1016/j.ocemod.2004.08.002
Correction and commentary for Ocean forecasting in terrain-following coordinates: Formulation and skill assessment of the Regional Ocean Modelling System, J. Comp. Phys. J. Comp. Phys, vol.227, issue.24, pp.3595-3624, 2009. ,
