Electrowetting of a 3D drop: Numerical modelling with electrostatic vector fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2010
The electrowetting process is commonly used to handle very small amounts of liquid on a solid surface. This process can be modelled mathematically with the help of the shape optimization theory. However, solving numerically the resulting shape optimization problem is a very complex issue, even for reduced models that occur in simplified geometries. Recently, the second author obtained convincing results in the 2D axisymmetric case. In this paper, we propose and analyze a method that is suitable for the full 3D case. © EDP Sciences, SMAI, 2010.
hal-00873057 , version 1 (15-10-2013)
Patrick Ciarlet, Claire Scheid. Electrowetting of a 3D drop: Numerical modelling with electrostatic vector fields. ESAIM: Mathematical Modelling and Numerical Analysis, 2010, 44 (4), pp.647-670. ⟨10.1051/m2an/2010014⟩. ⟨hal-00873057⟩
129 Consultations
0 Téléchargements
