Diffraction by a defect in an open waveguide: A Mathematical analysis based on a modal radiation condition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2009
We consider the scattering of a time-harmonic acoustic wave by a defect in a twodimensional open waveguide. The scattered wave satisfies the Helmholtz equation in a perturbed layered half-plane. We introduce a modal radiation condition based on a generalized Fourier transform which diagonalizes the transverse contribution of the Helmholtz operator. The uniqueness of the solution is proved by an original technique which combines a property of the energy flux with an argument of analyticity with respect to the generalized Fourier variable. The existence is then deduced classically from Fredholm's alternative by reformulating the scattering problem as a Lippmann-Schwinger equation by means of the Green's function for the layered half-plane. © 2009 Society for Industrial and Applied Mathematics.
Fichier non déposé
hal-00873068 , version 1 (16-10-2013)
Anne-Sophie Bonnet-Ben Dhia, Ghania Dakhia, Christophe Hazard, Lahcène Chorfi. Diffraction by a defect in an open waveguide: A Mathematical analysis based on a modal radiation condition. SIAM Journal on Applied Mathematics, 2009, 70 (3), pp.677-693. ⟨10.1137/080740155⟩. ⟨hal-00873068⟩
173 Consultations
0 Téléchargements
