Segmentation Driven Object Detection with Fisher Vectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ramazan Gokberk Cinbis
  • Fonction : Auteur
  • PersonId : 933132
Jakob Verbeek
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
We present an object detection system based on the Fisher vector (FV) image representation computed over SIFT and color descriptors. For computational and storage efficiency, we use a recent segmentation-based method to generate class-independent object detection hypotheses, in combination with data compression techniques. Our main contribution is a method to produce tentative object segmentation masks to suppress background clutter in the features. Re-weighting the local image features based on these masks is shown to improve object detection significantly. We also exploit contextual features in the form of a full-image FV descriptor, and an inter-category rescoring mechanism. Our experiments on the VOC 2007 and 2010 datasets show that our detector improves over the current state-of-the-art detection results.
paper_final.pdf (1.91 Mo) Télécharger le fichier
Format : Figure, Image
hal-00873134 , version 1 (15-10-2013)
hal-00873134 , version 2 (10-02-2014)
  • HAL Id : hal-00873134 , version 1
Ramazan Gokberk Cinbis, Jakob Verbeek, Cordelia Schmid. Segmentation Driven Object Detection with Fisher Vectors. ICCV 2013 - IEEE International Conference on Computer Vision, Dec 2013, Sydney, Australia. ⟨hal-00873134v1⟩
2920 Consultations
3044 Téléchargements
