Snooze: an Autonomic and Energy-Efficient Management System for Private Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Snooze is an open-source scalable, autonomic, and energy- efficient virtual machine (VM) management framework for private clouds. It allows users to build compute infrastructures from virtualized re- sources. Particularly, once installed and configured it allows its users to submit and control the life-cycle of a large number of VMs. For scal- ability, the system relies on a self-organizing and healing hierarchical architecture. Moreover, it performs energy-efficient distributed VM man- agement. Therefore, it implements features to monitor and estimate VM resource utilization (CPU, memory, network Rx, network Tx), detect and resolve overload/underload situations, perform dynamic VM consol- idation through live migration, and finally power management to save energy. Last but not least, it integrates a generic scheduler which allows to implement any VM placement algorithm. This demo will expose the Snooze's main properties (scalability, energy-efficiency, autonomy, and fault-tolerance) through its graphical interface.
demo-snooze.pdf (159.68 Ko) Télécharger le fichier
hal-00873486 , version 1 (15-10-2013)
  • HAL Id : hal-00873486 , version 1
Matthieu Simonin, Eugen Feller, Anne-Cécile Orgerie, Yvon Jégou, Christine Morin. Snooze: an Autonomic and Energy-Efficient Management System for Private Clouds. Energy Efficiency in Large Scale Distributed Systems, Apr 2013, Vienne, Austria. ⟨hal-00873486⟩
472 Consultations
249 Téléchargements
