Numerical Analysis of a reduced formulation of an elasto-acoustic scattering problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a reduced formulation for the elasto- acoustic scattering problem. The modeling is based on the On Surface Radiation Condition method. It leads to a discrete system which solution is assessed when using Discontinuous Finite Elements.
waves2013_submission_93.pdf (57.79 Ko) Télécharger le fichier
hal-00873633 , version 1 (16-10-2013)
  • HAL Id : hal-00873633 , version 1
Hélène Barucq, Juliette Chabassier, Julien Diaz, Elodie Estecahandy. Numerical Analysis of a reduced formulation of an elasto-acoustic scattering problem. WAVES 13 : 11th International Conference on Mathematical and Numerical Aspects of Waves, Jun 2013, Gammarth, Tunisia. ⟨hal-00873633⟩
301 Consultations
146 Téléchargements
