A General Trace-Based Framework of Logical Causality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
In component-based safety-critical embedded systems it is crucial to determine the cause(s) of the violation of a safety property, be it to issue a precise alert or to determine liability of component providers. In this paper we present an approach to blame components based on a single execution trace violating a safety property P. The diagnosis relies on counterfactual reasoning (what would have been the outcome if component C had behaved correctly?) to distinguish component failures that actually contributed to the outcome from failures that had little or no impact on the violation of P.
RR-8378.pdf (634.29 Ko) Télécharger le fichier
hal-00873665 , version 1 (16-10-2013)
hal-00873665 , version 2 (20-11-2013)
  • HAL Id : hal-00873665 , version 1
Gregor Gössler, Daniel Le Métayer. A General Trace-Based Framework of Logical Causality. [Research Report] RR-8378, 2013. ⟨hal-00873665v1⟩
Collections
INRIA-RRRT
295 Consultations
317 Téléchargements
