Overlaying Graph Links on Treemaps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Every graph can be decomposed into a tree structure plus a set of remaining edges. We describe a visualization technique that displays the tree structure as a Treemap and the remaining edges as curved links overlaid on the Treemap. Link curves are designed to show where the link starts and where it ends without requiring an explicit arrow that would clutter the already dense visualization. This technique is effective for visualizing structures where the underlying tree has some meaning, such as Web sites or XML documents with cross-references. Graphic attributes of the links - such as color or thickness - can be used to represent attributes of the edges. Users can choose to see all links at once or only the links to and from the node or branch under the cursor.
Fichier non déposé
hal-00875194 , version 1 (21-10-2013)
  • HAL Id : hal-00875194 , version 1
Jean-Daniel Fekete, David Wang, Niem Dang, Catherine Plaisant. Overlaying Graph Links on Treemaps. Information Visualization, IEEE, Oct 2003, Seattle, United States. ⟨hal-00875194⟩
195 Consultations
0 Téléchargements
