Grid Enabled Non-Rigid Registration with a Dense Transformation and A Priori Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Xavier Pennec
Nicholas Ayache
Multi-subject non-rigid registration algorithms using dense transformations often encounter cases where the transformation to be estimated requires a large spatial variability. In these cases, linear regularization methods are not sufficient. In this paper, we present an algorithm that uses a priori information about the nature of the images in order to find more adapted deformations. We also present a robustness improvement that gives higher weight to those points in the images that contain more information. Finally, a fast parallel implementation using networked personal computers is presented. Results show that our method can take into account the large variability of the inner brain structures. A parallel implementation allowed us to execute the registration algorithm in 5 minutes and future improvements will open the possibility of registering massive quantities of images.
hal-00875275 , version 1 (21-10-2013)
Radu Stefanescu, Xavier Pennec, Nicholas Ayache. Grid Enabled Non-Rigid Registration with a Dense Transformation and A Priori Information. MICCAI - Medical Image Computing and Computer Assisted Interventions 2003, Oct 2003, Montreal, Canada. pp.804--811, ⟨10.1007/978-3-540-39903-2_98⟩. ⟨hal-00875275⟩
Collections
INRIA INRIA2
69 Consultations
0 Téléchargements
