CLP(Intervals) Revisited, Proceedings of ILPS, pp.124-138, 1994. ,
Applying Interval Arithmetic to Real, Integer and Boolean Constraints, Journal of Logic Programming, vol.32, issue.1, pp.1-24, 1997. ,
The kinematic sensitivity of robotic manipulators to joint clearances, Proceedings of ASME Design Engineering Technical Con-ferences, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01941777
RealPaver: an Interval Solver Using Constraint Satisfaction Techniques, ACM Trans. Math. Softw, vol.852, issue.1, pp.138-156, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00480813
Kinematic clearance sensitivity analysis of spatial structures with revolute joints, ASME Journal of Mechanical Design, vol.124, issue.1, pp.52-57, 2002. ,
Applied Interval Analysis with Examples in Parameter and State Estimation, Robust Control and Robotics, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00845131
An Efficient and Safe Framework for Solving Optimization Problems, Journal of Computational and Applied Mathematics, vol.199, issue.2, pp.372-377, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00510304
Consistency Techniques for Numeric CSPs, Proceedings of IJCAI, pp.232-238, 1993. ,
Accuracy analysis of planar linkages by the matrix method. Mechanism and Machine Theory, vol.27, pp.507-516, 1992. ,
Consistency in Networks of Relations, Artificial Intelligence, vol.8, issue.1, pp.99-118, 1977. ,
Accuracy analysis of parallel manipulators with joint clearance, ASME Journal of Mechanical Design, vol.131, issue.1, pp.11013-11014, 2009. ,
Interval Analysis, 1966. ,
Uncertainty analysis of planar and spatial robots with joint clearances. Mechanism and Machine Theory, vol.35, pp.1239-1256, 2000. ,
A new technique for clearance influence analysis in spatial mechanisms, ASME Journal of Mechanical Design, vol.127, issue.3, pp.446-455, 2005. ,
Application of workspace generation techniques to determine the unconstrained motion of parallel manipulators, ASME Journal of Mechanical Design, vol.126, issue.2, pp.283-290, 2004. ,
ECLiPSe: A Platform for Constraint Logic Programming, 1997. ,
Position errors due to clearances in journal bearings, ASME Journal of Mechanisms, Transmissions, and Automation in Design, vol.111, issue.3, pp.315-320, 1989. ,
