Sensitivity of rough differential equations: an approach through the Omega lemma - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
The Itô map assigns the solution of a Rough Differential Equation, a generalization of an Ordinary Differential Equation driven by an irregular path, when existence and uniqueness hold. By studying how a path is transformed through the vector field which is integrated, we prove that the Itô map is Hölder or Lipschitz continuous with respect to all its parameters. This result unifies and weaken the hypotheses of the regularity results already established in the literature.
sensitivity-RDE.pdf (550.49 Ko) Télécharger le fichier
hal-00875670 , version 1 (22-10-2013)
hal-00875670 , version 2 (06-03-2015)
hal-00875670 , version 3 (25-05-2016)
hal-00875670 , version 4 (14-10-2016)
hal-00875670 , version 5 (31-10-2017)
hal-00875670 , version 6 (12-12-2017)
Copyright (Tous droits réservés)
  • HAL Id : hal-00875670 , version 4
Laure Coutin, Antoine Lejay. Sensitivity of rough differential equations: an approach through the Omega lemma. 2016. ⟨hal-00875670v4⟩
800 Consultations
719 Téléchargements
