On radial and directional controllability of bilinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2013
In this note we study two notions of controllability, called respectively radial controllability and directional controllability. They are both weakened versions of the classical notion of global controllability. We prove that for families of linear vector fields, the two notions are actually equivalent.
hal-00876014 , version 1 (23-10-2013)
Andrea Bacciotti, Jean-Claude Vivalda. On radial and directional controllability of bilinear systems. Systems and Control Letters, 2013, 62 (7), pp.575-580. ⟨10.1016/j.sysconle.2013.03.011⟩. ⟨hal-00876014⟩
462 Consultations
0 Téléchargements
