Learning the parts of objects by non-negative matrix factorization, Nature, vol.401, issue.10, pp.788-791, 1999. ,
Sparse image coding using learned overcomplete dictionaries, Proceedings of the 2004 14th IEEE Signal Processing Society Workshop Machine Learning for Signal Processing, 2004., pp.579-588, 2004. ,
DOI : 10.1109/MLSP.2004.1423021
Image Denoising Via Sparse and Redundant Representations Over Learned Dictionaries, IEEE Transactions on Image Processing, vol.15, issue.12, pp.3736-3745, 2006. ,
DOI : 10.1109/TIP.2006.881969
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.6477
Non-negative Matrix Factorization with Sparseness Constraints, J. Mach. Learn. Res, vol.5, issue.12, pp.1457-1469, 2004. ,
Algorithms for Non-negative Matrix Factorization, Advances in Neural Information Processing Systems 13: Proceedings of the 2000 Conference, pp.556-562, 2001. ,
K-SVD and its non-negative variant for dictionary design, Wavelets XI, pp.327-339, 2005. ,
DOI : 10.1117/12.613878
<tex>$rm K$</tex>-SVD: An Algorithm for Designing Overcomplete Dictionaries for Sparse Representation, IEEE Transactions on Signal Processing, vol.54, issue.11, pp.4311-4322, 2006. ,
DOI : 10.1109/TSP.2006.881199
Sparse nonnegative matrix factorization using 0 -constraints, IEEE International Workshop on Machine Learning for Signal Processing, pp.2010-83 ,
Orthogonal matching pursuit: recursive function approximation with applications to wavelet decomposition, Proceedings of 27th Asilomar Conference on Signals, Systems and Computers, 1993. ,
DOI : 10.1109/ACSSC.1993.342465
