K-NN search using local learning based on regression for image prediction with neighbor embedding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper describes a K-NN search method aided by local learning of subspace mappings for the problem of neighbor-embedding based image Intra prediction. The local learning of subspace mappings relies on multivariate linear regression. The method is used jointly with Locally Linear Embedding (LLE) as well as with a method inspired from Non Local Means (NLM) for prediction. Linear and kernel ridge regression are also considered directly for predicting the unknown pixels. Rate-distortion performances are then given in comparison with Intra prediction using LLE and classical K-NN search, as well as in comparison with H.264 Intra prediction modes.
Fichier non déposé
hal-00876123 , version 1 (23-10-2013)
  • HAL Id : hal-00876123 , version 1
Christine Guillemot, Safa Chérigui, Dominique Thoreau. K-NN search using local learning based on regression for image prediction with neighbor embedding. IEEE Intl. Conf. on Acoustics and Signal Processing (IEEE-ICASSP), May 2013, Vancouver, United States. ⟨hal-00876123⟩
140 Consultations
0 Téléchargements
