3D view synthesis with inter-view consistency
In this paper, we propose a new pipeline to synthesize virtual views by extrapolation. It allows us to generate virtual views far away from each other, each presenting the exact same level of quality. This inter-view consistency is key to seamlessly navigate between viewpoints. Its computational cost is also lower than that of existing approaches. We compare the proposed approach with state-of-the-art methods and show the effectiveness of this new view synthesis pipeline.
Traitement des images [eess.IV]
Wolinsky_acm2013.pdf (11.44 Mo)
Télécharger le fichier
poster.pdf (1 Mo)
Format : Autre
