Monitoring and Security for the Internet of Things - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anthéa Mayzaud
Rémi Badonnel
  • Fonction : Auteur
  • PersonId : 947216
Isabelle Chrisment
The concept of Internet of Things involves the deployment of Low power and Lossy Networks (LLN) allowing communications amongst pervasive devices such as embedded sensors. A dedicated routing protocol called RPL has been designed to consider the constraints of these LLN networks. However, the RPL protocol remains exposed to many security attacks that can be very costly in time and energy. In this paper, we propose to exploit risk management methods and techniques to evaluate the potentiality of attacks and to dynamically reduce the exposure of the RPL protocol while minimizing resources consumption.
llncs.pdf (199.77 Ko) Télécharger le fichier
hal-00876216 , version 1 (24-10-2013)
Paternité
Anthéa Mayzaud, Rémi Badonnel, Isabelle Chrisment. Monitoring and Security for the Internet of Things. 7th International Conference on Autonomous Infrastructure (AIMS), Jun 2013, Barcelona, Spain. pp.37-40, ⟨10.1007/978-3-642-38998-6_4⟩. ⟨hal-00876216⟩
434 Consultations
452 Téléchargements
