A stability estimate for ill-posed elliptic Cauchy problems in a domain with corners - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2007
We prove in this Note a stability estimate for ill-posed elliptic Cauchy problems in a domain with corners. This result completes an earlier result obtained for a smooth domain. To cite this article: L. Bourgeois, C. R. Acad. Sci. Paris, Ser. I 345 (2007). © 2007 Académie des sciences.
hal-00876225 , version 1 (24-10-2013)
Laurent Bourgeois. A stability estimate for ill-posed elliptic Cauchy problems in a domain with corners. Comptes Rendus. Mathématique, 2007, 345 (7), pp.385-390. ⟨10.1016/j.crma.2007.09.014⟩. ⟨hal-00876225⟩
104 Consultations
0 Téléchargements
