Mathematical analysis of the acoustic diffraction by a muffler containing perforated ducts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2005
We consider the three-dimensional scalar problem of acoustic propagation in a muffler. We develop and analyze a Fredholm-type formulation for a stationary fluid in the timeharmonic setting. We prove a homogenization result for a muffler containing periodically perforated ducts. Essentially, the perforated boundaries become completely transparent when the period of perforations, which is assumed to be of the same order as the size of perforations, tends to zero. We also derive a homogenized impedance condition when the perforated duct is coated by an absorbing material. We present numerical examples in two dimensions, obtained from coupling finite elements in the muffler with modal decompositions in the inlet and outlet ducts, which demonstrate the limiting validity of the theoretical results. © World Scientific Publishing Company.
Fichier non déposé
hal-00876243 , version 1 (04-11-2013)
Anne-Sophie Bonnet-Ben Dhia, Dora Drissi, Nabil Gmati. Mathematical analysis of the acoustic diffraction by a muffler containing perforated ducts. Mathematical Models and Methods in Applied Sciences, 2005, 15 (7), pp.1059-1090. ⟨10.1142/s0218202505000649⟩. ⟨hal-00876243⟩
213 Consultations
0 Téléchargements
