A mixed formulation of quasi-reversibility to solve the Cauchy problem for Laplace's equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2005
This work concerns the use of the method of quasi-reversibility to solve the Cauchy problem for Laplace's equation. We describe a mixed formulation of the method and its relationship with a classical formulation. A discretized formulation using finite elements of class C0 is derived from the mixed formulation, and convergence of the solution of this discretized problem with noisy data to the exact solution is analysed. Finally, a simple numerical example is implemented in order to show the feasibility of the method. © 2005 IOP Publishing Ltd.
hal-00876244 , version 1 (04-11-2013)
Laurent Bourgeois. A mixed formulation of quasi-reversibility to solve the Cauchy problem for Laplace's equation. Inverse Problems, 2005, 21 (3), pp.1087-1104. ⟨10.1088/0266-5611/21/3/018⟩. ⟨hal-00876244⟩
107 Consultations
0 Téléchargements
