Simulation of muffler's transmission losses by a homogenized finite element method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Acoustics Année : 2004
In this work, we are interested in the modelling of the acoustic attenuation of exhaust mufflers including perforated ducts, and its numerical computation. The study is worked out in harmonic time regime, for the two-dimensional case. The hole diameter and the center-to-center distance between consecutive holes are supposed of same order, and small compared to the size of the muffler. The formulation is derived by using multiscale techniques and matching the asymptotic expansions. The numerical method couples finite elements in the muffler with modal decomposition in the inlet and the outlet of the duct.
Fichier non déposé
hal-00876248 , version 1 (04-11-2013)
Anne-Sophie Bonnet-Ben Dhia, Dora Drissi, Nabil Gmati. Simulation of muffler's transmission losses by a homogenized finite element method. Journal of Computational Acoustics, 2004, 12 (3), pp.447-474. ⟨10.1142/s0218396x04002304⟩. ⟨hal-00876248⟩
154 Consultations
0 Téléchargements
