Dimensions and bases of hierarchical tensor-product splines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2014
We prove that the dimension of trivariate tensor-product spline space of tri-degree (m,m,m) with maximal order of smoothness over a three- dimensional domain coincides with the number of tensor-product B-spline basis functions acting effectively on the domain considered. A domain is required to belong to a certain class. This enables us to show that, for a cer- tain assumption about the configuration of a hierarchical mesh, hierarchical B-splines span the spline space. This paper presents an extension to three-dimensional hierarchical meshes of results proposed recently by Giannelli and Ju ̈ttler for two-dimensional hierarchical meshes.
revision.pdf (329.53 Ko) Télécharger le fichier
hal-00876557 , version 1 (24-10-2013)
Dmitry Berdinsky, Taiwan Kim, Cesare Bracco, Durkbin Cho, Bernard Mourrain, et al.. Dimensions and bases of hierarchical tensor-product splines. Journal of Computational and Applied Mathematics, 2014, 257, pp.86-104. ⟨10.1016/j.cam.2013.08.019⟩. ⟨hal-00876557⟩
Collections
INRIA INSMI INRIA2
232 Consultations
237 Téléchargements
