New interface
Conference papers
Automated Controllers for Bandwidth Allocation in Network Virtualization
M. Said Seddiki 1, 2, * Bilel Nefzi 1 Ye-Qiong Song 1 Mounir Frikha 2
* Corresponding author
1 MADYNES - Management of dynamic networks and services
Inria Nancy - Grand Est, LORIA - NSS - Department of Networks, Systems and Services
Abstract : The concept of network virtualization was introduced to facilitate flexible service deployment for the future Internet. This recent technology provides a powerful tool to run multiple logical networks on the same physical substrate defined as virtual networks (VNs). Each physical link is split into virtual links and each VN receives a fraction of the available capacity. Bandwidth allocation for multiple VMs aims at sharing the physical links among multiple VNs. It is a critical challenge for both service providers (SPs) and infrastructure providers (InPs). This allocation should take into account the quality of service (QoS) requirements of the flows that are crossing each VN. In this paper, we consider a virtualized network environment where the SP deploys multiple VNs with different links' capacity demands and QoS requirements. Each VN competes with other VNs to receive fractions of physical links managed by multiple InPs. We present a two-layer controller system that adapts to the dynamic change of the workload of each VN. The system uses a prediction-based approach in order to find the optimal request for each VN. The request depends on the estimation of the relationship between the VN performance in terms of packet delays and the actual and past allocations. Then, due to the capacity constraint of the physical link, the system adjusts the offered bandwidth for each of them. Our model offers flexible distributed autonomous control of the bandwidth allocation to maintain the offered QoS to each VN at the desired level in response to the dynamics of the workload. Our mechanism provides an optimum allocation of the physical links by distributing the bandwidth periodically. It also offers the possibility of adjusting the VNs' parameters to take into account the current network behaviour to avoid bottleneck virtual links.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-00877579
Contributor : M. Said Seddiki Connect in order to contact the contributor
Submitted on : Tuesday, October 7, 2014 - 1:20:17 PM
Last modification on : Wednesday, February 2, 2022 - 5:00:56 PM
Long-term archiving on: : Friday, April 14, 2017 - 3:02:32 PM
File
06742795.pdf
Identifiers
  • HAL Id : hal-00877579, version 2
Collections
Citation
M. Said Seddiki, Bilel Nefzi, Ye-Qiong Song, Mounir Frikha. Automated Controllers for Bandwidth Allocation in Network Virtualization. IPCCC - 32nd IEEE International Performance Computing and Communications Conference - 2013, Oct 2013, San Diego, United States. ⟨hal-00877579v2⟩
Share
Metrics
Record views
254
Files downloads
390
