Extended query language and composition for the XR data model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
The XR data model allows capturing rich semistructured corpora of documents (XML) with annotations (RDF triples). A simple query language for XR was presented in previous work, which allowed to retrieve results from from XR databases but not to build new XR content. This work makes two contributions. First, we present an extension of the query language giving powerful content structuring and grouping capabilities which enables flexible generation of new XR results. Second, we provide a query-view composition algorithm which enables the efficient evaluation of XR queries over previously defined XR views.
RR-8931.pdf (966.03 Ko) Télécharger le fichier
hal-00879511 , version 1 (04-11-2013)
  • HAL Id : hal-00879511 , version 1
Alin Deutsch, François Goasdoué, Julien Leblay, Ioana Manolescu. Extended query language and composition for the XR data model. [Research Report] RR-8391, INRIA. 2013. ⟨hal-00879511⟩
562 Consultations
356 Téléchargements
