New interface
Conference papers
Efficient Distributed Monitoring in 6LoWPAN Networks
Abdelkader Lahmadi 1 Alexandre Boeglin 1 Olivier Festor 1
1 MADYNES - Management of dynamic networks and services
Inria Nancy - Grand Est, LORIA - NSS - Department of Networks, Systems and Services
Abstract : Monitoring constrained, low power and lossy networks is essential to many operations including troubleshooting, forensics, performance management. The main challenge for the monitoring plane in these networks is to efficiently cope with both frequently changing topologies and constrained resources. We present a novel algorithm and the supporting framework that improves a poller-pollee based architecture. We empower the poller-pollee placement decision process and operation by exploiting available routing data to monitor nodes status. In addition, monitoring data is efficiently embedded in any messages flowing through the network, drastically reducing monitoring overhead. Our approach is validated through both simulation, implementation and deployment on a 6LoWPAN-enabled network. Results demonstrate that our approach is less aggressive and less resource consuming than its competitors.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-00879550
Contributor : Abdelkader Lahmadi Connect in order to contact the contributor
Submitted on : Tuesday, November 5, 2013 - 10:40:18 AM
Last modification on : Saturday, June 25, 2022 - 7:42:49 PM
Long-term archiving on: : Thursday, February 6, 2014 - 4:34:21 AM
File
CNSM_WSN_Monitoring.pdf
Identifiers
  • HAL Id : hal-00879550, version 1
Collections
Citation
Abdelkader Lahmadi, Alexandre Boeglin, Olivier Festor. Efficient Distributed Monitoring in 6LoWPAN Networks. CNSM - 9th International Conference on Network and Service Management - 2013, University of Zürich, Oct 2013, Zurich, Switzerland. ⟨hal-00879550⟩
Share
Metrics
Record views
238
Files downloads
197
