Extending IP Flow-Based Network Monitoring with Location Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2015
IP Flow-based monitoring lacks a mechanism to associate measured IP Flow information with the geographic location of the device where theIP Flows have been observed. This document defines a set of guidelines and best practices to extend IP Flow monitoring protocols with location information of the device (both fixed and mobile) that acts as an IP Flow metering process.
draft-irtf-nmrg-location-ipfix-05.pdf (72.39 Ko) Télécharger le fichier
hal-00879567 , version 1 (04-11-2013)
hal-00879567 , version 2 (14-12-2015)
hal-00879567 , version 3 (17-12-2015)
  • HAL Id : hal-00879567 , version 3
Olivier Festor, Abdelkader Lahmadi, Rick Hofstede, Aiko Pras. Extending IP Flow-Based Network Monitoring with Location Information. 2015. ⟨hal-00879567v3⟩
207 Consultations
364 Téléchargements
