Not so random RLC AL-FEC codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2013
This document introduces a class of linear codes, derived from Random Linear Codes (RLC), mixing binary and non binary coefficients, as well as a particular structure. The goal is to define highly efficient erasure codes to be used in both sliding/elastic encoding window mode and block code mode.
ietf88_not_so_random_rlc_v1_1.pdf (891.17 Ko) Télécharger le fichier
hal-00879834 , version 1 (12-11-2013)
  • HAL Id : hal-00879834 , version 1
Vincent Roca, Kazuhisa Matsuzono. Not so random RLC AL-FEC codes. IETF88 - NWCRG meeting, Nov 2013, Vancouver, Canada. 2013. ⟨hal-00879834⟩
191 Consultations
68 Téléchargements
