The Method of Quarter-Squares, 593, 1889. [answer to Glaisher's article, 1042. ,
The philosophy of arithmetic, pp.245-257, 1820. ,
Tetragonometria tabularia. Leipzig: Groschian, 1690. [other editions were published in 1709 and 1712] ,
Quarter-squares revisited: earlier tables, division of labor in table construction, and later implementations in analog computers, 2007. ,
Tables of quarter-squares, sociologic, 2007. ,
Tables arithmonomiques, fondées sur le rapport du rectangle au carré ; ou, le calcul réduit à son dernier degré de simplification. Vannes, 1832. [not seen] ,
