The logarithmic tables of Edward Sang and his daughters, Historia Mathematica, vol.30, issue.1, pp.47-84, 2003. ,
DOI : 10.1016/S0315-0860(02)00018-6
De natura et praeclaro usu simplicissimae speciei numerorum trigonalium. The Hague: Husson, 1762 ,
Mémoire sur divers points d'analyse, pp.229-265, 1809. ,
The Method of Quarter-Squares, 593, 1889. [answer to Glaisher's article, 1042. ,
New and concise general tables for computing the obliquity of the ecliptic, converting mean solar into sidereal time determining the equation to equal attitudes etc, p.1836 ,
Sur divers moyens d'abréger la multiplication, Annales de mathématiques pures et appliquées, pp.157-166, 1816. ,
Also published as part of the Report of the forty-third meeting of the British Association for the advancement of science, London: John Murray, 1874. A review by R. Radau was published in the Bulletin des sciences mathématiques et astronomiques, pp.7-27, 1876. ,
On multiplication by a table of single entry, Philosophical magazine, vol.6, issue.38, pp.331-347, 1878. ,
The method of quarter squares [see Foster's article, Nature, vol.4015, pp.573-576, 1041. ,
The method of quarter squares, Nature, pp.419-1889, 1045. ,
The method of quarter squares, Journal of the Institute of Actuaries, vol.28, pp.227-235, 1890. ,
Table, mathematical The Encyclopaedia Britannica, pp.325-336, 1911. ,
Die Viertelquadratemethode und das Pediometer des Joseph Friedrich Schiereck, 4. Symposium zur Entwicklung der Rechentechnik, 2009. ,
On Binary Multiplication Using the Quarter Square Algorithm, IEEE Transactions on Computers, vol.25, issue.9, pp.957-960, 1976. ,
DOI : 10.1109/TC.1976.1674723
A digital quarter square multiplier, IEEE Transactions on Computers, C, vol.29, pp.258-261, 1980. ,
Toasirtafeln, zur leichtern Berechnung des Längen-Flächenund Kubik-Inhaltes und der verschiedenen Münz-Maß-und Gewichts-Beträge ,
Neue Multiplikationstafeln : ein unentbehrliches Hülfsmittel für Jedermann, um schnell, sicher und ohne Ermüdung zu rechnen, 1851. ,
Pseudo logarithms. The Mathematics Teacher, pp.2-6, 1959. ,
A table of quarter-squares of all integer numbers up to 100,000, by which the product of two factors may be found by the aid of addition and subtraction alone " . The Assurance magazine, and journal of the, Institute of Actuaries, vol.6, issue.4, pp.234-237, 1856. ,
On a method of finding the product of two factors by means of the addition and subtraction of natural numbers. The Assurance Magazine, and, Journal of the Institute of Actuaries, vol.6, pp.121-129, 1856. ,
Table of quarter-squares of all integer numbers, up to 100,000, by which the product of two factors may be found by the aid of addition and subtraction alone, p.1856 ,
On a method of using the Table of quarter squares " . The Assurance Magazine, and, Journal of the Institute of Actuaries, vol.9, issue.2, pp.112-115, 1860. ,
The philosophy of arithmetic, pp.245-257, 1820. ,
Tetragonometria tabularia. Leipzig: Groschian, 1690. [other editions were published in 1709 and 1712] ,
Quarter-squares revisited: earlier tables, division of labor in table construction, and later implementations in analog computers, 2007. ,
Tables of quarter-squares, sociologic, 2007. ,
Tables arithmonomiques, fondées sur le rapport du rectangle au carré ; ou, le calcul réduit à son dernier degré de simplification. Vannes, 1832. [not seen] ,
Tafel der Viertel-Quadrate aller Zahlen von 1 bis 20009 zur Erleichterung des Multiplizierens vierstelliger Zahlen, 1933. ,
A reconstruction of Crelle's Rechentafeln (1820) Technical report, LORIA, 2011. [This is a reconstruction of ,
A reconstruction of Kulik's table of multiplication (1851) [This is a reconstruction of, 2011. ,
A reconstruction of Blater's table of quarter-squares (1887)This is a reconstruction of ,
A reconstruction of Bürger's table of quarter-squares (1817)This is a reconstruction of ,
A reconstruction of Centnerschwer's table of quarter-squares (1825)This is a reconstruction of ,
A reconstruction of Joncourt's table of triangular numbers (1762)This is a reconstruction of ,
A reconstruction of Laundy's table of quarter-squares (1856)This is a reconstruction of ,
A reconstruction of Ludolf's Tetragonometria tabularia (1690)This is a reconstruction of ,
A reconstruction of Merpaut's table of quarter-squares (1832)This is a reconstruction of ,
A reconstruction of Plassmann's table of quarter-squaresThis is a reconstruction of, 1933. ,
A reconstruction of Voisin's table of quarter-squares (1817)This is a reconstruction of ,
Beschreibung des Pediometers, eines Instruments, um den Flächeninhalt in Karten ohne Rechnung zu erhalten, Polytechnisches Journal, vol.82, pp.251-265, 1841. ,
Note on a formula by aid of which and of table of single entry the continued product of any set of numbers (or at least a given constant multiple thereof) may be effected by additions and subtractions only without the use of logarithms, pp.430-436, 1854. ,
On Multiplication by aid of a Table of Single Entry, The Assurance Magazine and Journal of the Institute of Actuaries, vol.4, issue.03, pp.236-238, 1854. ,
DOI : 10.1017/S2046165800022875
Tables de multiplication, ou, logarithmes des nombres entiers depuis 1 jusqu'à 20,000, etc ,
Die Multipliziertafeln: ihre Ausgestaltung und Verwendung, 2003. ,
Die Rekonstruktion der Rechenmaschine von Schiereck 1829, 2006. ,
Review of " J. Bojko: Neue Tafel der Viertelquadrate etc, Zeitschrift für Mathematik und Physik, p.222, 1911. ,
