Two-Component Signal Transduction, Annual Review of Biochemistry, vol.69, issue.1, pp.183-215, 2000. ,
DOI : 10.1146/annurev.biochem.69.1.183
Signaling Mechanisms of HAMP Domains in Chemoreceptors and Sensor Kinases, Annual Review of Microbiology, vol.64, issue.1, pp.101-122, 2010. ,
DOI : 10.1146/annurev.micro.112408.134215
The cytoplasmic helical linker domain of receptor histidine kinase and methyl-accepting proteins is common to many prokaryotic signalling proteins, FEMS Microbiology Letters, vol.176, issue.1, pp.111-116, 1999. ,
DOI : 10.1111/j.1574-6968.1999.tb13650.x
MicroReview: Functional similarities among twocomponent sensors and methyl-accepting chemotaxis proteins suggest a role for linker region amphipathic helices in transmembrane signal transduction, Molecular Microbiology, vol.33, 1999. ,
The HAMP Domain Structure Implies Helix Rotation in Transmembrane Signaling, Cell, vol.126, issue.5, 2006. ,
DOI : 10.1016/j.cell.2006.06.058
Structure of Concatenated HAMP Domains Provides a Mechanism for Signal Transduction, Structure, vol.18, issue.4, pp.436-448, 2010. ,
DOI : 10.1016/j.str.2010.01.013
Mutational Analysis of the Connector Segment in the HAMP Domain of Tsr, the Escherichia coli Serine Chemoreceptor, Journal of Bacteriology, vol.190, issue.20, pp.6676-6685, 2008. ,
DOI : 10.1128/JB.00750-08
Mutational analyses of HAMP helices suggest a dynamic bundle model of input-output signalling in chemoreceptors, Molecular Microbiology, vol.232, issue.5, pp.801-814, 2009. ,
DOI : 10.1111/j.1365-2958.2009.06819.x
Structure-Function Relationships in the HAMP and Proximal Signaling Domains of the Aerotaxis Receptor Aer, Journal of Bacteriology, vol.190, issue.6, pp.2118-2127, 2008. ,
DOI : 10.1128/JB.01858-07
Complex Formation and Light Activation in Membrane-Embedded Sensory Rhodopsin II as Seen by Solid-State NMR Spectroscopy, Structure, vol.18, issue.3, 2010. ,
DOI : 10.1016/j.str.2010.01.011
URL : http://doi.org/10.1016/j.str.2010.01.011
Structural Analysis of a HAMP Domain: THE LINKER REGION OF THE PHOTOTRANSDUCER IN COMPLEX WITH SENSORY RHODOPSIN II, Journal of Biological Chemistry, vol.280, issue.46, pp.38767-38775, 2005. ,
DOI : 10.1074/jbc.M509391200
Salt-driven Equilibrium between Two Conformations in the HAMP Domain from Natronomonas pharaonis: THE LANGUAGE OF SIGNAL TRANSFER?, Journal of Biological Chemistry, vol.283, issue.42, pp.28691-28701, 2008. ,
DOI : 10.1074/jbc.M801931200
HAMP Domain Signal Relay Mechanism in a Sensory Rhodopsin-Transducer Complex, Journal of Biological Chemistry, vol.287, issue.25, pp.21316-21325, 2012. ,
DOI : 10.1074/jbc.M112.344622
Mutational Analysis of a Conserved Signal-Transducing Element: the HAMP Linker of the Escherichia coli Nitrate Sensor NarX, Journal of Bacteriology, vol.185, issue.1, pp.89-97, 2003. ,
DOI : 10.1128/JB.185.1.89-97.2003
Structural and Functional Studies of the HAMP Domain of EnvZ, an Osmosensing Transmembrane Histidine Kinase in Escherichia coli, Journal of Biological Chemistry, vol.282, issue.36, pp.26401-26408, 2007. ,
DOI : 10.1074/jbc.M701342200
Mechanism of Regulation of Receptor Histidine Kinases, Structure, vol.20, issue.1, pp.56-66, 2012. ,
DOI : 10.1016/j.str.2011.11.014
The Mechanisms of HAMP-Mediated Signaling in Transmembrane Receptors, Structure, vol.19, issue.3, pp.378-385, 2011. ,
DOI : 10.1016/j.str.2011.01.006
Structural Analysis of Ligand Stimulation of the Histidine Kinase NarX, Structure, vol.17, issue.2, pp.190-201, 2009. ,
DOI : 10.1016/j.str.2008.12.013
The Piston Rises Again, Structure, vol.17, issue.9, pp.1149-1151, 2009. ,
DOI : 10.1016/j.str.2009.08.005
Molecular mechanism of transmembrane signaling by the aspartate receptor: a model., Proceedings of the National Academy of Sciences, vol.93, issue.6, pp.2545-2550, 1996. ,
DOI : 10.1073/pnas.93.6.2545
Biphasic control logic of HAMP domain signalling in the Escherichia coli serine chemoreceptor, Molecular Microbiology, vol.73, issue.3, pp.596-611, 2011. ,
DOI : 10.1111/j.1365-2958.2011.07577.x
Role of the HAMP Domain Region of Sensory Rhodopsin Transducers in Signal Transduction, Biochemistry, vol.50, issue.4, pp.574-580, 2011. ,
DOI : 10.1021/bi101032a
URL : https://hal.archives-ouvertes.fr/hal-00784550
Molecular modeling of the HAMP domain of sensory rhodopsin II transducer from Natronomonas pharaonis, BIOPHYSICS, vol.6, pp.27-36, 2010. ,
DOI : 10.2142/biophysics.6.27
Comparative Simulations of the Ground State and the M-Intermediate State of the Sensory Rhodopsin II???Transducer Complex with a HAMP Domain Model, Biochemistry, vol.51, issue.30, pp.5958-5966, 2012. ,
DOI : 10.1021/bi300696b
Transmembrane Signaling of Chemotaxis Receptor Tar: Insights from Molecular Dynamics Simulation Studies, Biophysical Journal, vol.100, issue.12, pp.2955-2963, 2011. ,
DOI : 10.1016/j.bpj.2011.05.030
Transmembrane Helix Dynamics of Bacterial Chemoreceptors Supports a Piston Model of Signalling, PLoS Computational Biology, vol.7, issue.10, 2011. ,
DOI : 10.1371/journal.pcbi.1002204.s004
Assembly of the Transmembrane Domain of E. coli PhoQ Histidine Kinase: Implications for Signal Transduction from Molecular Simulations, PLoS Computational Biology, vol.10, issue.1, 2013. ,
DOI : 10.1371/journal.pcbi.1002878.s007
Mechanism of Bacterial Signal Transduction Revealed by Molecular Dynamics of Tsr Dimers and Trimers of Dimers in Lipid Vesicles, PLoS Computational Biology, vol.8, issue.9, 2012. ,
DOI : 10.1371/journal.pcbi.1002685.t001
Investigating protein dynamics in collective coordinate space, Current Opinion in Structural Biology, vol.9, issue.2, pp.164-169, 1999. ,
DOI : 10.1016/S0959-440X(99)80023-2
Systematic Validation of Protein Force Fields against Experimental Data, PLoS ONE, vol.7, 2012. ,
Are Protein Force Fields Getting Better? A Systematic Benchmark on 524 Diverse NMR Measurements, Journal of Chemical Theory and Computation, vol.8, issue.4, pp.1409-1414, 2012. ,
DOI : 10.1021/ct2007814
The SWISS-MODEL Repository and associated resources, Nucleic Acids Research, vol.37, issue.Database, pp.387-392, 2009. ,
DOI : 10.1093/nar/gkn750
GROMACS 4:?? Algorithms for Highly Efficient, Load-Balanced, and Scalable Molecular Simulation, Journal of Chemical Theory and Computation, vol.4, issue.3, pp.435-447, 2008. ,
DOI : 10.1021/ct700301q
Extending the treatment of backbone energetics in protein force fields: Limitations of gas-phase quantum mechanics in reproducing protein conformational distributions in molecular dynamics simulations, Journal of Computational Chemistry, vol.44, issue.Pt 6 Pt 1, pp.1400-1415, 2004. ,
DOI : 10.1002/jcc.20065
Comparison of multiple Amber force fields and development of improved protein backbone parameters, Proteins: Structure, Function, and Bioinformatics, vol.43, issue.3, pp.712-725, 2006. ,
DOI : 10.1002/prot.21123
Improved side-chain torsion potentials for the Amber ff99SB protein force field, Proteins: Structure, Function, and Bioinformatics, vol.105, pp.1950-1958, 2010. ,
DOI : 10.1002/prot.22711
Well-Tempered Metadynamics: A Smoothly Converging and Tunable Free-Energy Method, Physical Review Letters, vol.100, issue.2, 2008. ,
DOI : 10.1103/PhysRevLett.100.020603
Polymorphic transitions in single crystals: A new molecular dynamics method, Journal of Applied Physics, vol.52, issue.12, pp.7182-7190, 1981. ,
DOI : 10.1063/1.328693
Conformations of amino acids in proteins, Acta Crystallographica Section D Biological Crystallography, vol.58, issue.5, pp.768-776, 2002. ,
DOI : 10.1107/S0907444902003359
