Appendix of "Mining Software Repair Models for Reasoning on the Search Space of Automated Program Fixing"
This is the companion paper of "Mining Software Repair Models for Reasoning on the Search Space of Automated Program Fixing", accepted for publication in Empirical Software Engineering (Springer) on Sep. 11, 2013.
Génie logiciel [cs.SE]
appendix-mining-repair-actions.pdf (188.82 Ko)
Télécharger le fichier
dataByProject.xml (787.83 Ko)
dataSummarized.xml (91.08 Ko)
dataset_survey_Martinez_et_al_2013.zip (1.58 Mo)
