Model Discrepancy in Robotic Calibration: Its Influence on the Experimental Parameter Identification of a Parallel Space Telescope - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The model of a robot may not be able to consider all the physical phenomena influencing the manipulator performances since they are too numerous and/or difficult to measure: this is model discrepancy. For a highly-accurate active space telescope, an important source of inaccuracy was measured using photogrammetry: the deformation of its mobile platform. This deformation cannot be directly measured in space and needs to be properly modeled in order to enable the telescope calibration with the available measurements. Two incremental models are proposed and the parameter observability is discussed. After experimental calibration, a micrometer accuracy can be reached. The influence of model discrepancy on the experimental parameter identification is finally discussed.
Fichier non déposé
hal-00903848 , version 1 (13-11-2013)
  • HAL Id : hal-00903848 , version 1
Thibault Gayral, David Daney, Marc Bernot. Model Discrepancy in Robotic Calibration: Its Influence on the Experimental Parameter Identification of a Parallel Space Telescope. IROS - IEEE/RSJ Int. Conf. on Intelligent Robots and Systems - 2013, Nov 2013, Tokyo, Japan. ⟨hal-00903848⟩
90 Consultations
0 Téléchargements
