A note on two problems in connexion with graphs Numerische mathematik, pp.269-271, 1959. ,
Predicting positive and negative links in online social networks, Proceedings of the 19th international conference on World wide web, WWW '10, pp.641-650, 2010. ,
DOI : 10.1145/1772690.1772756
Evolution of run times with respect to the number of vertices Three implementations are compared: our two implementations -with and without using external memory -and a distributed Dijkstra implementation referred to as CPU Dijkstra. All computations were run on 64 cluster nodes Community detection in networks with positive and negative links, Physical Review E, vol.8, issue.80 3, p.36115, 2009. ,
Hypothesizing about Causal Networks with Positive and Negative Effects by Meta-level Abduction, Inductive Logic Programming, pp.114-129, 2011. ,
DOI : 10.1007/978-3-642-21295-6_15
Accelerating Large Graph Algorithms on the GPU Using CUDA, High performance computing?HiPC, pp.197-208, 2007. ,
DOI : 10.1007/978-3-540-77220-0_21
Solving path problems on the GPU, Parallel Computing, vol.36, issue.5-6, pp.241-253, 2010. ,
DOI : 10.1016/j.parco.2009.12.002
A task parallel algorithm for finding all-pairs shortest paths using the GPU, International Journal of High Performance Computing and Networking, vol.7, issue.2, pp.87-98, 2012. ,
DOI : 10.1504/IJHPCN.2012.046384
Blocked United Algorithm for the All-Pairs Shortest Paths Problem on Hybrid CPU-GPU Systems, IEICE Transactions on Information and Systems, vol.95, issue.12, pp.2759-2768, 2012. ,
DOI : 10.1587/transinf.E95.D.2759
The all-pair shortest-path problem in sharedmemory heterogeneous systems, 2013. ,
Parallel multilevel k-way partitioning scheme for irregular graphs, Proceedings of the 1996 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '96, pp.96-129, 1998. ,
DOI : 10.1145/369028.369103
MPI: the complete reference, 1995. ,
Better performance at lower occupancy, Proceedings of the GPU Technology Conference, 2010. ,
Leda: A platform for combinatorial and geometric computing, 1999. ,
Online scheduling of mpi-2 programs with hierarchical work stealing, Computer Architecture and High Performance Computing SBAC-PAD 2007. 19th International Symposium on. IEEE, pp.247-254, 2007. ,
Boost c++ libraries, p.36, 2009. ,
