S. Childress, Mechanics of Swimming and Flying, Cambridge Studies in Mathematical Biology, vol.2, 1981.
DOI : 10.1017/CBO9780511569593
J. San-martín, J. Scheid, T. Takahashi, and T. , Convergence of the Lagrange--Galerkin Method for the Equations Modelling the Motion of a Fluid-Rigid System, SIAM Journal on Numerical Analysis, vol.43, issue.4, pp.1536-157110, 1137.
DOI : 10.1137/S0036142903438161
R. Glowinski, . Pan, . Tw, T. Hesla, D. Joseph et al., A distributed Lagrange multiplier/fictitious domain method for the simulation of flow around moving rigid bodies: application to particulate flow, Computer Methods in Applied Mechanics and Engineering, vol.184, issue.2-4
DOI : 10.1016/S0045-7825(99)00230-3
. Eng, Vistas in domain decomposition and parallel processing in computational mechanics, pp.241-267, 2000.
R. Glowinski, . Pan, . Tw, T. Hesla, D. Joseph et al., A Fictitious Domain Approach to the Direct Numerical Simulation of Incompressible Viscous Flow past Moving Rigid Bodies: Application to Particulate Flow, Journal of Computational Physics, vol.169, issue.2, pp.363-426, 2001.
DOI : 10.1006/jcph.2000.6542
C. Peskin, The immersed boundary method, Acta Numer, vol.11, pp.479-51710, 2002.
L. Formaggia and N. , F: A stability analysis for the arbitrary Lagrangian Eulerian formulation with finite elements, East-West J. Numer. Math, vol.7, issue.2, pp.105-131, 1999.
L. Gastaldi, A priori error estimates for the Arbitrary Lagrangian Eulerian formulation with finite elements, Journal of Numerical Mathematics, vol.9, issue.2, pp.123-156, 2001.
DOI : 10.1515/JNMA.2001.123
B. Maury, Direct Simulations of 2D Fluid-Particle Flows in Biperiodic Domains, Journal of Computational Physics, vol.156, issue.2, pp.325-3516365, 1999.
DOI : 10.1006/jcph.1999.6365
B. Maury and G. , Fluid-particle flow: a symmetric formulation, Comptes Rendus de l'Acad??mie des Sciences - Series I - Mathematics, vol.324, issue.9, pp.1079-108410, 1997.
DOI : 10.1016/S0764-4442(97)87890-1
O. Pironneau, On the transport-diffusion algorithm and its applications to the Navier-Stokes equations, Numerische Mathematik, vol.March, issue.3, pp.309-332, 1982.
DOI : 10.1007/BF01396435
E. Süli, Convergence and nonlinear stability of the Lagrange-Galerkin method for the Navier-Stokes equations, Numerische Mathematik, vol.10, issue.4, pp.459-483, 1988.
DOI : 10.1007/BF01396329
Y. Achdou and . Guermond, Convergence Analysis of a Finite Element Projection/Lagrange--Galerkin Method for the Incompressible Navier--Stokes Equations, SIAM Journal on Numerical Analysis, vol.37, issue.3, pp.799-826, 2000.
DOI : 10.1137/S0036142996313580
C. Grandmont, V. Guimet, and Y. Maday, NUMERICAL ANALYSIS OF SOME DECOUPLING TECHNIQUES FOR THE APPROXIMATION OF THE UNSTEADY FLUID STRUCTURE INTERACTION, Mathematical Models and Methods in Applied Sciences, vol.11, issue.08, pp.1349-1377, 2001.
DOI : 10.1142/S0218202501001367
J. San-martín, L. Smaranda, and . Takahashi, Convergence of a finite element/ALE method for the Stokes equations in a domain depending on time, Journal of Computational and Applied Mathematics, vol.230, issue.2, pp.521-545, 2009.
DOI : 10.1016/j.cam.2008.12.021
G. Legendre and . Takahashi, Convergence of a Lagrange-Galerkin method for a fluid-rigid body system in ALE formulation, ESAIM: Mathematical Modelling and Numerical Analysis, vol.42, issue.4, pp.609-64410, 1051.
DOI : 10.1051/m2an:2008020
URL : https://hal.archives-ouvertes.fr/hal-00142870
J. San-martín, J. Scheid, T. Takahashi, and T. , Convergence of the Lagrange???Galerkin method for a fluid???rigid system, Comptes Rendus Mathematique, vol.339, issue.1, pp.59-64, 2004.
DOI : 10.1016/j.crma.2004.04.007
J. San-martín, . Scheid, . Jf, and . Smaranda, A time discretization scheme of a characteristics method for a fluid???rigid system with discontinuous density, Comptes Rendus Mathematique, vol.348, issue.15-16, pp.15-16, 2010.
DOI : 10.1016/j.crma.2010.07.004
J. San-martín, . Scheid, . Jf, and . Smaranda, A modified Lagrange???Galerkin method for a fluid-rigid system with discontinuous density, Numerische Mathematik, vol.53, issue.2, pp.341-382, 2012.
DOI : 10.1007/s00211-012-0460-1
J. San-martín, J. Scheid, T. Takahashi, and T. , An Initial and Boundary Value Problem Modeling of Fish-like Swimming, Archive for Rational Mechanics and Analysis, vol.272, issue.3, pp.429-45510, 2008.
DOI : 10.1007/s00205-007-0092-2
. Arnold, V: Ordinary Differential Equations Translated from the third, 1992.
J. San-martín, . Scheid, . Jf, and . Smaranda, L: The Lagrange-Galerkin method for a fluid-deformable system, 2013.
