Abstract : This document describes an XML presentation syntax and XML Schemas for OWL 1.0 sublanguages: OWL Lite, OWL DL, and OWL Full. This document has been written to meet the requirement that OWL 1.0 should have an XML serialization syntax (R15 in [OWL Requirement]). It is not intended to be a normative specification. Instead, it represents a suggestion of one possible XML presentation syntax for OWL.
