Intersection types and lambda models, Theoretical Computer Science, vol.355, issue.2, pp.108-126, 1993. ,
DOI : 10.1016/j.tcs.2006.01.004
URL : http://doi.org/10.1016/j.tcs.2006.01.004
Domains and lambda-calculi, 1998. ,
DOI : 10.1017/cbo9780511983504
URL : https://hal.archives-ouvertes.fr/inria-00070008
Checking polynomial time complexity with types, IFIP TCS of IFIP Conference Proceedings, pp.370-382, 2002. ,
The Lambda-Calculus, its syntax and semantics. Studies in Logic and the Foundation of Mathematics, p.9, 1984. ,
A term calculus for Intuitionistic Linear Logic, Proc. of the 1st Int. Conf. on Typed Lambda Calculus and Applications, pp.75-90 ,
DOI : 10.1007/BFb0037099
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.31.8467
Abstract, Journal of Functional Programming, vol.1, issue.05, pp.699-722, 1996. ,
DOI : 10.1145/174675.174707
A filter lambda model and the completeness of type assignment, The Journal of Symbolic Logic, vol.37, issue.04, pp.931-940, 1983. ,
DOI : 10.1002/malq.19800261902
A semantics for lambda calculi with resources, Mathematical Structures in Computer Science, vol.9, issue.4, pp.437-482, 1999. ,
DOI : 10.1017/S0960129599002893
Exact bounds for lengths of reductions in typed lambda-calculus, J. of Symbolic Logic, vol.66, issue.3, pp.1277-1285, 2001. ,
Categorical Models for Simply Typed Resource Calculi, Electronic Notes in Theoretical Computer Science, vol.265, issue.3, pp.213-230, 2010. ,
DOI : 10.1016/j.entcs.2010.08.013
URL : https://hal.archives-ouvertes.fr/hal-00527229
A convenient differential category. CoRR, abs/1006, p.3140, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00492424
Full abstraction for lambda calculus with resources and convergence testing, Trees in Algebra and Programming, 21st Int. Colloquium (CAAP'96), pp.302-316, 1996. ,
DOI : 10.1007/3-540-61064-2_45
Complexity of strongly normalising ?-terms via nonidempotent intersection types Filter models: non-idempotent intersection types, orthogonality and polymorphism, Proc. of the 14th Int. Conf. on Foundations of Software Science and Computation Structures (FOSSACS'11) Proc. of the 20th Annual Conf. of the European Association for Computer Science Logic (CSL'11), LIPIcs. Schloss Dagstuhl LCI Mogbil. Soft lambda-calculus: a language for polynomial time computation. CoRR, cs.LO/0312015, pp.13-31, 2003. ,
Alcune proprietà delle forme ?-?-normali nel ?K-calcolo Preservation of strong normalisation in named lambda calculi with explicit substitution and garbage collection, Computing Science in the Netherlands (CSN '95), pp.25-62, 1968. ,
A new type assignment for ??-terms, Archiv f??r Mathematische Logik und Grundlagenforschung, vol.5, issue.1, pp.139-156, 1978. ,
DOI : 10.1007/BF02011875
URL : http://www.digizeitschriften.de/download/PPN379931524_0019/PPN379931524_0019___log16.pdf
Functional characterization of some semantic equalities inside ??-calculus, Proc. of the 6th Intern, pp.133-146 ,
DOI : 10.1007/3-540-09510-1_11
A proof of strong normalisation using domain theory. Logic. Methods Comput, [dC05] D. de Carvalho. Intersection types for light affine lambda calculus. ENTCS, pp.31133-152, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00432490
Execution time of lambda-terms via denotational semantics and intersection types, p.4251, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00319822
Behavioural Inverse Limit Models, Theoret. Comput. Sci, vol.316, issue.2, pp.1-349, 2004. ,
DOI : 10.1016/j.tcs.2004.01.023
URL : http://doi.org/10.1016/j.tcs.2004.01.023
Compositional characterisations of <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-terms using intersection types, Theoretical Computer Science, vol.340, issue.3, pp.459-495, 2005. ,
DOI : 10.1016/j.tcs.2005.03.011
Reductions, intersection types, and explicit substitutions, Mathematical Structures in Computer Science, vol.13, issue.1, pp.55-85, 2003. ,
DOI : 10.1017/S0960129502003821
The differential lambda-calculus, Theoretical Computer Science, vol.309, issue.1-3, pp.1-41, 2003. ,
DOI : 10.1016/S0304-3975(03)00392-X
URL : https://hal.archives-ouvertes.fr/hal-00150572
Typing untyped ??-terms, or reducibility strikes again!, Annals of Pure and Applied Logic, vol.91, issue.2-3, pp.231-270, 1998. ,
DOI : 10.1016/S0168-0072(97)00047-X
URL : http://doi.org/10.1016/s0168-0072(97)00047-x
Strong normalization and typability with intersection types, Notre Dame J. Formal Loigc, vol.37, issue.1 2, pp.44-52, 1996. ,
Intersection Types for the Resource Control Lambda Calculi, Proc. of the 8th Int. Colloquium on Theoretical Aspects of Computing, pp.116-134, 2011. ,
DOI : 10.1016/0304-3975(92)90297-S
URL : https://hal.archives-ouvertes.fr/ensl-00654755
Linear logic, Thèse d'´ etat Gaboardi and S. R. D. Rocca. A soft type assignment system for lambda -calculus, pp.1-101, 1972. ,
DOI : 10.1016/0304-3975(87)90045-4
URL : https://hal.archives-ouvertes.fr/inria-00075966
The formulae-as-types notion of construction ,
Curry: Essays on Combinatory Logic, Lambda Calculus, and Formalism, pp.479-490, 1969. ,
The theory of calculi with explicit substitutions revisited A theory of explicit substitutions with safe and full composition. Logic, Proc. of the 16th Annual Conf. of the European Association for Computer Science Logic, pp.238-252, 2007. ,
Extending the Explicit Substitution Paradigm, Proc. of the 16th Int. Conf. on Rewriting Techniques and Applications(RTA'05), pp.407-422, 2005. ,
DOI : 10.1007/978-3-540-32033-3_30
URL : https://hal.archives-ouvertes.fr/hal-00148847
Resource operators for ??-calculus, Krivine. Lambda-calcul Types et modèles, pp.419-473, 1990. ,
DOI : 10.1016/j.ic.2006.08.008
URL : https://hal.archives-ouvertes.fr/hal-00148539
Typed lambda-calculus in classical Zermelo-Fraenkel set theory, Arch. Math. Log, vol.40, issue.4, pp.189-205, 2001. ,
Principality and decidable type inference for finiterank intersection types, Proc. of the 26th Annual ACM Symp. on Principles of Programming Languages (POPL'99), pp.161-174, 1999. ,
DOI : 10.1145/292540.292556
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.4246
Typing and computational properties of lambda expressions, Theoret. Comput. Sci, vol.44, issue.1, pp.51-68, 1986. ,
Intersection types for explicit substitutions, Information and Computation, vol.189, issue.1, pp.17-42, 2004. ,
DOI : 10.1016/j.ic.2003.09.004
URL : https://hal.archives-ouvertes.fr/hal-00150285
Classical F ? , orthogonality and symmetric candidates ,
URL : https://hal.archives-ouvertes.fr/hal-00150283
Mellì es. Typed ?-calculi with explicit substitution may not terminate, Proc. of the 2nd Int. Conf. on Typed Lambda Calculus and Applications (TLCA'95), pp.3-20, 2008. ,
Focalisation and classical realisabilityMellì es and J. Vouillon. Recursive polymorphic types and parametricity in an operational framework, Proc. of the 18th Annual Conf. of the European Association for Computer Science Logic 20th Annual IEEE Symp. on Logic in Computer Science, pp.409-423, 2005. ,
DOI : 10.1007/978-3-642-04027-6_30
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.402.5477
Types, potency, and idempotency: why nonlinearity and amnesia make a type system work, Proc. of the 9th ACM Intern. Conf. on Functional Programming, pp.138-149, 2004. ,
DOI : 10.1145/1016850.1016871
Proofs of strong normalisation for second order classical natural deduction ,
Les ressources explicites vues par la théorie de la réécriture Complexity of normalization in the pure typed lambda calculus, J. of Symbolic Logic The L. E. J. Brouwer Centenary Symposium. North-Holland, pp.1461-1479, 1982. ,
A realizability interpretation of the theory of species Complete restrictions of the Intersection Type Discipline, Logic Colloquium, pp.240-251, 1975. ,
Intersection type assignment systems, Theoretical Computer Science, vol.151, issue.2, pp.385-435, 1995. ,
DOI : 10.1016/0304-3975(95)00073-6
Perpetual Reductions in??-Calculus, Information and Computation, vol.149, issue.2, pp.173-225, 1999. ,
DOI : 10.1006/inco.1998.2750
then there exists ? ? ? such that ? ? ? ? ?? x : F , so ? = (x : F ) so F ? ?(x) ,
then (x : F ) ? ? and x : F ? ? ? ?? x : F ,
There exists ? ? ? such that there exist ? 1 , ? 2 and A such that ? 1 ,
There exists A such that So there exists ? ? ? such that ? ? ? ? ?? M : A ? F and there exists ? ? ? such that ,
There exists A ? u such that A ? F ? ?x.M ? . So there exists ? ? ? such that ? ? ? ? ?? ?x.M : A ? F . Hence, there exists U such that ,
There exists ? ? (?, x ? u) such that ? ? ? ? ?? M : F . ? If x ? f v(M ), then there exist ? 1 ? ? and A ? u such that ? = ? 1 , x : A (using Lemma 5.1). So we have ? 1 ? ? ? ?? ?x ,
Hence there exist ? 1 , ? 2 , A and U such that ? = ? 1 ? ? 2 ,
? If U ? N ? there exist A and ? such that ,
(x) = ?, so there exists A ? ?(x). Also, there exist ? ? and U such that ? = (? ? ,
So there exists ? ? ? such that ? ? ? ? ?? C y,z x (M ) : F . Hence there exist ? ? , U , V 1 and V 2 such, V 1 ? V 2 )) and ? ? , x : U, y : V 1 , z : V 2 ? ? ? ?? M : F ,
V 1 ? V 2 ) ? ?(x) or U ? (V 1 ? V 2 ) = ?. So U , V 1 and V 2 are either equal to ? or are in ?(x) Hence (? ? , x : U, y : V 1 , z : V 2 ) ? (?, y ? ?(x), z ? ?(x)), Therefore F ? M ?,y ??(x),z ??(x) ,
z ??(x) , then there exists ? ? (?, x ? ?(x), y ? ?(y)). So there exist ? ?, 1 and V 2 such that ? = (? ? , x : U, y : V 1 , z : V 2 ) and U , V 1 and V 2 are ,
