A penalization method to take into account obstacles in incompressible flows, Numer. Math, vol.81, issue.4, pp.497-520, 1999. ,
Optimisation aérodynamique par réduction de modèle POD et contrle optimal Application au sillage laminaire d'un cylindre circulaire, 2004. ,
Modeling and simulation of fish-like swimming, Journal of Computational Physics, vol.230, issue.2, pp.329-348, 2011. ,
DOI : 10.1016/j.jcp.2010.09.017
URL : https://hal.archives-ouvertes.fr/inria-00546358
Numerical study and physical analysis of the pressure and velocity fields in the near wake of a circular cylinder, Journ. Fluid. Mech, p.165, 1986. ,
A vortex level set method for the twoway coupling of an incompressible fluid with colliding rigid bodies, J. Comput. Phys, vol.227, issue.21, pp.9121-9137, 2008. ,
Flow patterns generated by oblate medusan jellyfish: field measurements and laboratory analyses, The Journal of Experimental Biology, vol.208, pp.1257-1265, 2005. ,
Numerical simualtion of flow over two circular cylinders in tandem arrangement, Journal of Hydrodynamics, vol.23, pp.114-126, 2011. ,
Numerical simulation of flows around two circular cylonders by mesh-free least square-based finite difference methods, Int. J.for Num. Meth. in Fluids, vol.53, pp.305-332, 2007. ,
Arbitrary lagrangian-eulerian method for navier stokes equations with moving boundaries, Computer Methods on Applied Math. and Engineering, vol.193, pp.4819-4836, 2004. ,
A sharp interface immersed boundary method for compressible viscous flows, J. Comput. Phys, vol.225, pp.528-553, 2007. ,
A second order accurate symmetric discretization of the poisson equation on irregular domains, J. Comput . Phys, vol.176, pp.205-227, 2002. ,
A Nonreflecting Outlet Boundary Condition for Incompressible Unsteady Navier-Stokes Calculations, J. Comp. Phys, vol.107, issue.2, pp.239-253, 1993. ,
High-resolution simulations of the flow around an impulsively started cylinder using vortex methods, J. Fluid Mech, vol.296, pp.1-38, 1995. ,
Sources of spurious force oscillations from an immersed boundary method for moving-body problems, Journal of Computational Physics, vol.230, issue.7, pp.2677-2695, 2011. ,
The immersed interface method for the navier stokes equations with singular forces, J. Comput. Phys, vol.171, pp.822-842, 2001. ,
Simulating flows with moving rigid boundary using immersed-boundary method, Computers & Fluids, vol.39, issue.1, pp.152-167, 2010. ,
Sharp interface castesian grid method ii : a technique fir simulationg droplet interactions with surfaces of arbitrary shape, J. Comput. Phys, pp.210-242, 2005. ,
Numerical investigation of convective heat transfer in unsteady flow past two cylinders in tandem arrangements, Int. J. of Heat and Fluid Flow, vol.29, pp.1309-1318, 2008. ,
Sharp interface cartesian grid method i: an easily implemented technique for 3d moving boundary computations, J. Comput. Phys, pp.210-211, 2005. ,
Numerical simulation of flow interference between two cylinders in tandem and side-by-side arrangements, J.of Fluids and Structures, vol.15, pp.327-350, 2001. ,
A versatile sharp interface immersed boundary method for incompressible flows with complex boundaries, J. Comput. Phys, pp.227-4825, 2008. ,
Immersed boundary methods, Annu. Rev. Fluid. Mech, pp.1-27, 2005. ,
Unsteady incompressible flows past two cylinders in tandem and staggered arrangements, Int. J. for Num. Meth. in Fluides, vol.25, pp.1315-1344, 1997. ,
Level Set Methods and Dynamic Implicit Surfaces, 2003. ,
Fronts propagating with curvature-dependent speed: Algorithms based on hamilton-jacobi formulations, J. Comput. Phys, vol.79, p.12, 1988. ,
Vortex Methods for High-Resolution Simulations of Viscous Flow Past Bluff Bodies of General Geometry, Journal of Computational Physics, vol.165, issue.2, pp.354-406, 2000. ,
DOI : 10.1006/jcph.2000.6614
A sharp-interface immersed boundary method with improved mass conservation and reduced spurious pressure oscillations, Journal of Computational Physics, vol.230, issue.19, pp.7347-7363, 2011. ,
A fast marching level set method for monotonically advancing fronts., Proceedings of the National Academy of Sciences, vol.93, issue.4, pp.1591-1595, 1996. ,
DOI : 10.1073/pnas.93.4.1591
A. Level Set Methods and Fast Marching Methods, 1999. ,
Evolution, Implementation, and Application of Level Set and Fast Marching Methods for Advancing Fronts, Journal of Computational Physics, vol.169, issue.2, pp.503-555, 2001. ,
DOI : 10.1006/jcph.2000.6657
Numerical predictions of low Reynolds number flows over two tandem circular cylinders, International Journal for Numerical Methods in Fluids, vol.12, issue.5, pp.423-447, 2005. ,
DOI : 10.1002/fld.812
Flow around two circular cylinders by randomvortex method, J. of Fluids and Structures, vol.6, issue.6, pp.641-670, 1992. ,
A level set approach for computing solutions to incompressible 2-phade flow, Journal of Computational Physics, vol.114, pp.146-159, 1994. ,
Computational of multiphase flows, Adv. Appl. Mech, vol.39, pp.91-120, 2003. ,
Sharp interface castesian grid method iii : solidification of pure materials and binary solutions, J. Comput. Phys, vol.210, pp.55-74, 2005. ,
