Incremental policy generation for finite-horizon DEC-POMDPs, ICAPS, 2009. ,
An investigation into mathematical programming for finite horizon decentralized POMDPs, JAIR, vol.37, pp.329-396, 2010. ,
Policy search by dynamic programming, NIPS, 2003. ,
Policy iteration for decentralized control of Markov decision processes, JAIR, vol.34, pp.89-132, 2009. ,
The complexity of decentralized control of Markov decision processes, Mathematics of Operations Research, vol.27, issue.4, 2002. ,
Exact dynamic programming for decentralized POMDPs with lossless policy compression, ICAPS, pp.20-27, 2008. ,
Collective decision under partial observability -a dynamic local interaction model, IJCCI (ECTA-FCTA), pp.146-155, 2011. ,
The Linear Programming Approach to Approximate Dynamic Programming, Operations Research, vol.51, issue.6, pp.850-865, 2003. ,
DOI : 10.1287/opre.51.6.850.24925
Scaling up decentralized MDPs through heuristic search, UAI, pp.217-226, 2012. ,
Producing efficient error-bounded solutions for transition independent decentralized MDPs, AAMAS, 2013. ,
Dynamic programming for partially observable stochastic games, AAAI, pp.709-715, 2004. ,
Constraint-based dynamic programming for decentralized POMDPs with structured interactions, AAMAS, pp.561-568, 2009. ,
Networked distributed POMDPs : A synthesis of distributed constraint optimization and POMDPs, AAAI, pp.133-139, 2005. ,
Incremental clustering and expansion for faster optimal planning in Dec-POMDPs, pp.449-509, 2013. ,
Optimal and approximate Q-value functions for decentralized POMDPs, JAIR, vol.32, pp.289-353, 2008. ,
Lossless clustering of histories in decentralized POMDPs, AAMAS, pp.577-584, 2009. ,
A survey of point-based POMDP solvers, JAAMAS, pp.1-51, 2012. ,
The optimal control of partially observable Markov decision processes over a finite horizon, Operations Research, vol.21, issue.5, pp.1071-1088, 1973. ,
Heuristic search value iteration for POMDPs, UAI, pp.520-527, 2004. ,
Scaling up optimal heuristic search in Dec- POMDPs via incremental expansion, IJCAI, pp.2027-2032, 2011. ,
MAA* : A heuristic search algorithm for solving decentralized POMDPs, UAI, pp.568-576, 2005. ,
