Adaptive Management of Migratory Birds Under Sea Level Rise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Samuel Nicol
  • Fonction : Auteur
  • PersonId : 914251
Olivier Buffet
The best practice method for managing ecological systems under uncertainty is adaptive management (AM), an iterative process of reducing uncertainty while simultaneously optimizing a management objective. Existing solution methods used for AM problems assume that the system dynamics are stationary, i.e., described by one of a set of pre-defined models. In reality ecological systems are rarely stationary and evolve over time. Importantly, the effects of climate change on populations are unlikely to be captured by stationary models. Practitioners need efficient algorithms to implement AM on real-world problems. AM can be formulated as a hidden model Markov Decision Process (hmMDP), which allows the state space to be factored and shows promise for the rapid resolution of large problems. We provide an ecological dataset and performance metrics for the AM of a network of shorebird species utilizing the East Asian-Australasian flyway given uncertainty about the rate of sea level rise. The non-stationary system is modelled as a stationary POMDP containing hidden alternative models with known probabilities of transition between them. We challenge the POMDP community to exploit the simplifications allowed by structuring the AM problem as an hmMDP and improve our benchmark solutions.
ijcai13a.pdf (122.38 Ko) Télécharger le fichier
hal-00907334 , version 1 (21-11-2013)
  • HAL Id : hal-00907334 , version 1
Samuel Nicol, Olivier Buffet, Takuya Iwamura, Iadine Chadès. Adaptive Management of Migratory Birds Under Sea Level Rise. IJCAI - 23rd International Joint Conference on Artificial Intelligence - 2013, Aug 2013, Pékin, China. pp.2955-2957. ⟨hal-00907334⟩
210 Consultations
231 Téléchargements
