Robust subspace based fault detection, Proc. 18th IFAC World Congress, 2011. ,
Vibration-based structural damage identification, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Science, vol.359, pp.131-149, 1778. ,
A summary review of vibration-based damage identification methods, Shock and Vibration Digest, vol.30, pp.91-105, 1998. ,
Vibration based condition monitoring: a review, Structural Health Monitoring, vol.3, issue.4, pp.355-377, 2004. ,
The fundamental axioms of structural health monitoring, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Science, vol.463, pp.1639-1664, 2007. ,
Damage detection of the Z24 Bridge using control charts, Mechanical Systems and Signal Processing, vol.17, issue.1, pp.163-170, 2003. ,
Dynamic monitoring of a long span arch bridge, Engineering Structures, vol.30, pp.3034-3044, 2008. ,
Monitoring historical masonry structures with operational modal analysis: Two case studies, Mechanical Systems and Signal Processing, vol.24, issue.5, pp.1291-1305, 2010. ,
Damage detection using outlier analysis, Journal of Sound and Vibration, vol.229, issue.3, pp.647-667, 2000. ,
Structural damage diagnosis by Kalman model based on stochastic subspace identification, Structural Health Monitoring, vol.3, issue.2, pp.103-119, 2004. ,
Kalman filter damage detection in the presence of changing process and measurement noise, Mechanical Systems and Signal Processing ,
Subspace-based fault detection algorithms for vibration monitoring, Automatica, vol.36, issue.1, pp.101-109, 2000. ,
Statistical model-based damage detection and localization: subspace-based residuals and damage-tonoise sensitivity ratios, Journal of Sound and Vibration, vol.275, issue.3, pp.769-794, 2004. ,
Merging sensor data from multiple temperature scenarios for vibration-based monitoring of civil structures, Structural Health Monitoring, vol.7, issue.2, pp.129-142, 2008. ,
Null subspace-based damage detection of structures using vibration measurements, Mechanical Systems and Signal Processing, vol.20, issue.3, pp.611-626, 2006. ,
, Subspace Identification for Linear Systems: Theory, Implementation, Applications, 1996.
The asymptotic local approach to change detection and model validation, IEEE Transactions on Automatic Control, vol.32, issue.7, pp.583-592, 1987. ,
URL : https://hal.archives-ouvertes.fr/inria-00075990
Detecting changes in the AR parameters of a nonstationary ARMA process, Stochastics -An International Journal of Probability and Stochastic Processes, vol.16, issue.1, pp.137-155, 1986. ,
On the distribution of the left singular vectors of a random matrix and its applications, Statistics & Probability Letters, vol.78, issue.15, pp.2275-2280, 2008. ,
Generalized inverse of a matrix and its applications, 1971. ,
Advanced numerical computation of ? 2 -tests for fault detection and isolation, 5th Symp. Fault Detection, Supervision and Safety for Technical Processes (SAFEPROCESS), pp.211-216, 2003. ,
Uncertainty calculation in (operational) modal analysis, Mechanical Systems and Signal Processing, vol.21, issue.6, pp.2359-2373, 2007. ,
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, pp.346-366, 2013. ,
, Matrix computations, 1996.
