Cube Testers and Key Recovery Attacks on Reduced-Round MD6 and Trivium, FSE, pp.1-22, 2009. ,
DOI : 10.1007/978-3-642-03317-9_1
The KHAZAD legacy-level block cipher. Primitive submitted to NESSIE, p.4, 2000. ,
Cryptanalysis of Skipjack Reduced to 31 Rounds Using Impossible Differentials, Lecture Notes in Computer Science, vol.1592, pp.12-23, 1999. ,
DOI : 10.1007/3-540-48910-X_2
Differential Cryptanalysis of DES-like Cryptosystems, Lecture Notes in Computer Science, vol.537, pp.2-21, 1990. ,
DOI : 10.1007/3-540-38424-3_1
Slide Attacks, Lecture Notes in Computer Science, vol.1636, pp.245-259, 1999. ,
DOI : 10.1007/3-540-48519-8_18
Biclique Cryptanalysis of the Full AES, Lecture Notes in Computer Science, vol.7073, pp.344-371, 2011. ,
DOI : 10.1007/978-3-642-25385-0_19
PRESENT: An Ultra-Lightweight Block Cipher, Paillier and Verbauwhede [46], pp.450-466 ,
DOI : 10.1007/978-3-540-74735-2_31
Key-Alternating Ciphers in a Provable Setting: Encryption Using a Small Number of Public Permutations, Lecture Notes in Computer Science, vol.7237, pp.45-62, 2012. ,
DOI : 10.1007/978-3-642-29011-4_5
PRINCE ??? A Low-Latency Block Cipher for Pervasive Computing Applications, pp.208-225 ,
DOI : 10.1007/978-3-642-34961-4_14
Higher-Order Differential Properties of Keccak and Luffa, Joux [32], pp.252-269 ,
DOI : 10.1007/978-3-642-13858-4_15
URL : https://hal.archives-ouvertes.fr/inria-00537741
KATAN and KTANTAN ??? A Family of Small and Efficient Hardware-Oriented Block Ciphers, CHES, pp.272-288, 2009. ,
DOI : 10.1007/978-3-642-04138-9_20
Trivium, The eSTREAM Finalists, pp.244-266, 2008. ,
DOI : 10.1007/978-3-540-68351-3_18
A Very Compact ???Perfectly Masked??? S-Box for AES, ACNS, pp.446-459, 2008. ,
DOI : 10.1007/978-3-540-68914-0_27
Towards Sound Approaches to Counteract Power-Analysis Attacks, Lecture Notes in Computer Science, vol.1666, pp.398-412, 1999. ,
DOI : 10.1007/3-540-48405-1_26
Side channel cryptanalysis of a higher order masking scheme, Paillier and Verbauwhede [46], pp.28-44 ,
Cryptanalysis of Block Ciphers with Overdefined Systems of Equations, Lecture Notes in Computer Science, vol.2501, pp.267-287, 2002. ,
DOI : 10.1007/3-540-36178-2_17
Nessie proposal: NOEKEON, 2000. ,
Rijndael candidate for aes, AES Candidate Conference, pp.343-348, 2000. ,
DOI : 10.1007/0-387-23483-7_358
The Wide Trail Design Strategy, IMA Int. Conf., volume 2260 of Lecture Notes in Computer Science, pp.222-238, 2001. ,
DOI : 10.1007/3-540-45325-3_20
Pairs and triplets of des S-Boxes, J. Cryptology, pp.1-25, 1995. ,
Key Recovery Attacks on 3-round Even-Mansour (with Applications!), Eurocrypt rump session, 2013. ,
Breaking Grain-128 with Dynamic Cube Attacks, Joux [32], pp.167-187 ,
DOI : 10.1007/978-3-642-17401-8_16
A Framework for Chosen IV Statistical Analysis of Stream Ciphers, INDOCRYPT, pp.268-281, 2007. ,
DOI : 10.1007/978-3-540-77026-8_20
Chosen IV Statistical Analysis for Key Recovery Attacks on Stream Ciphers, Lecture Notes in Computer Science, vol.5023, pp.236-245, 2008. ,
DOI : 10.1007/978-3-540-68164-9_16
Super-Sbox Cryptanalysis: Improved Attacks for AES-Like Permutations, Lecture Notes in Computer Science, vol.6147, pp.365-383, 2010. ,
DOI : 10.1007/978-3-642-13858-4_21
DES and Differential Power Analysis The ???Duplication??? Method, CHES, pp.158-172, 1999. ,
DOI : 10.1007/3-540-48059-5_15
The LED Block Cipher, Preneel and Takagi [48], pp.326-341 ,
DOI : 10.1007/978-3-642-23951-9_22
Grain: a stream cipher for constrained environments, International Journal of Wireless and Mobile Computing, vol.2, issue.1, pp.86-93, 2007. ,
DOI : 10.1504/IJWMC.2007.013798
Improved Rebound Attack on the Finalist Gr??stl, FSE, Lecture Notes in Computer Science, 2012. ,
DOI : 10.1007/978-3-642-34047-5_7
Bicliques for Preimages: Attacks on Skein-512 and the SHA-2 Family, Lecture Notes in Computer Science, vol.7549, pp.244-263, 2012. ,
DOI : 10.1007/978-3-642-34047-5_15
A Fast and Provably Secure Higher-Order Masking of AES S-Box, Preneel and Takagi [48], pp.95-107 ,
DOI : 10.1007/978-3-642-23951-9_7
Conditional Differential Cryptanalysis of NLFSR-Based Cryptosystems, Abe [1], pp.130-145 ,
DOI : 10.1007/978-3-642-17373-8_8
Truncated and higher order differentials, Lecture Notes in Computer Science, vol.1008, pp.196-211, 1994. ,
DOI : 10.1007/3-540-60590-8_16
Known-Key Distinguishers for Some Block Ciphers, ASIACRYPT, pp.315-324, 2007. ,
DOI : 10.1007/978-3-540-76900-2_19
Integral Cryptanalysis, Lecture Notes in Computer Science, vol.2365, pp.112-127, 2002. ,
DOI : 10.1007/3-540-45661-9_9
Side-Channel Leakage of Masked CMOS Gates, Lecture Notes in Computer Science, vol.3376, pp.351-365, 2005. ,
DOI : 10.1007/978-3-540-30574-3_24
Linear Cryptanalysis Method for DES Cipher, Lecture Notes in Computer Science, vol.765, pp.386-397, 1993. ,
DOI : 10.1007/3-540-48285-7_33
The Rebound Attack: Cryptanalysis of Reduced Whirlpool and Gr??stl, Fast Software Encryption -FSE 2009, p.5665 ,
DOI : 10.1007/978-3-642-03317-9_16
Differential Analysis of the LED Block Cipher, pp.190-207 ,
DOI : 10.1007/978-3-642-34961-4_13
Known and Chosen Key Differential Distinguishers for Block Ciphers, Lecture Notes in Computer Science, vol.6829, pp.29-48, 2010. ,
DOI : 10.1007/978-3-642-24209-0_3
A Side-Channel Analysis Resistant Description of the AES S-Box, Gilbert and Handschuh [26], pp.413-423 ,
DOI : 10.1007/11502760_28
An Efficient Masking Scheme for AES Software Implementations, Lecture Notes in Computer Science, vol.3786, pp.292-305, 2005. ,
DOI : 10.1007/11604938_23
PICARO ??? A Block Cipher Allowing Efficient Higher-Order Side-Channel Resistance, ACNS, pp.311-328, 2012. ,
DOI : 10.1007/978-3-642-31284-7_19
Higher-order glitches free implementation of the aes using secure multiparty computation protocols, Preneel and Takagi [48], pp.63-78 ,
Nessie proposal: KHAZAD, 2000. ,
On weaknesses of non-surjective round functions, Des. Codes Cryptography, pp.253-266, 1997. ,
Block Ciphers Implementations Provably Secure Against Second Order Side Channel Analysis, Lecture Notes in Computer Science, vol.5086, pp.127-143, 2008. ,
DOI : 10.1007/978-3-540-71039-4_8
Provably Secure Higher-Order Masking of AES, CHES, pp.413-427, 2010. ,
DOI : 10.1007/978-3-642-15031-9_28
Non-full-active Super-Sbox Analysis: Applications to ECHO and Gr??stl, Abe [1], pp.38-55 ,
DOI : 10.1007/978-3-642-17373-8_3
Higher Order Masking of the AES, Lecture Notes in Computer Science, vol.3860, pp.208-225, 2006. ,
DOI : 10.1007/11605805_14
ICEBERG : An Involutional Cipher Efficient for Block Encryption in Reconfigurable Hardware, Lecture Notes in Computer Science, vol.3017, pp.279-299, 2004. ,
DOI : 10.1007/978-3-540-25937-4_18
The World Is Not Enough: Another Look on Second-Order DPA, pp.112-129 ,
DOI : 10.1007/978-3-642-17373-8_7
Generic Side-Channel Distinguishers: Improvements and Limitations, Lecture Notes in Computer Science, vol.6841, pp.354-372, 2011. ,
DOI : 10.1007/978-3-642-22792-9_20
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.5137
The Myth of Generic DPA???and the Magic of Learning, Cryptology ePrint Archive, vol.256, 2012. ,
DOI : 10.1007/978-3-319-04852-9_10
Meet-in-the-middle path for 12 rounds ,
