Interval method for calibration of parallel robots: Vision-based experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mechanism and Machine Theory Année : 2006
This paper is a theoretical and experimental study of how interval arithmetic and analysis methods can be used to achieve (1) numerical certification of the kinematic calibration of parallel robots, and (2) a possible validation of the kinematic model used in calibration. First, a detailed description is given of our experimental device and vision-based measurement method. The usual calibration methods are then reviewed and applied to our experimental data set, yielding a motivation for numerical certification of the results. Next, interval calibration methods (which have already been described in a previous work) are also reviewed and applied to the data. Finally, the experimental results are discussed and interpreted.
Mots clés
hal-00907729 , version 1 (21-11-2013)
David Daney, Nicolas Andreff, Gilles Chabert, Yves Papegay. Interval method for calibration of parallel robots: Vision-based experiments. Mechanism and Machine Theory, 2006, 41 (8), pp.929 - 944. ⟨10.1016/j.mechmachtheory.2006.03.014⟩. ⟨hal-00907729⟩
102 Consultations
0 Téléchargements
