Performance on a semantic verbal fluency task across time: dissociation between clustering, switching, and categorical exploitation processes. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Clinical and Experimental Neuropsychology Année : 2010
The aims of this study were to investigate semantic retrieval processes and errors across time during a semantic fluency task and to specify their components (i.e., executive vs. semantic). To do so, we analyzed the productions of 50 healthy participants (using the "supermarket" fluency task). The scores were compared before and after a 30-s interval. Across time, the results showed a decrease in the number of words produced and hard switching. Cluster switching and the number of intrusions remained constant, while clustering, and both the number of exemplars and repetitions increased. These results are discussed in terms of a progressive involvement of a semantic cognitive strategy of retrieval.
Psychologie
Fichier non déposé
hal-00907998 , version 1 (22-11-2013)
Catriona Raboutet, Hélène Sauzéon, Marc-Michel Corsini, Jerome Rodrigues, Sabine Langevin, et al.. Performance on a semantic verbal fluency task across time: dissociation between clustering, switching, and categorical exploitation processes.. Journal of Clinical and Experimental Neuropsychology, 2010, 32 (3), pp.268-80. ⟨10.1080/13803390902984464⟩. ⟨hal-00907998⟩
64 Consultations
0 Téléchargements
