Compressive Sensing DSI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Compressive Sensing (CS) [2], [1] offers an efficient way to decrease the number of measurements required in Diffusion Spectrum Imaging (DSI). This method aims to reconstruct the Ensemble Average Propagator (EAP) and, for the purpose of this contest, we compute the numerical Orientation Distribution Function (ODF) by integrating the EAP over a solid angle. In this abstract, we briefly describe three important points underlying the CS technique in order to accelerate DSI, namely the sparsity, the Restricted Isometry Property (RIP) and the ï¿¿1 reconstruction scheme. Due to the high b-values required in the sampling protocol, our approach enters the heavyweight sampling category. Nevertheless, only 64 measurements are used for the reconstruction.
Imagerie
Fichier non déposé
hal-00908209 , version 1 (22-11-2013)
  • HAL Id : hal-00908209 , version 1
Sylvain L. Merlet, Michael Paquette, Rachid Deriche, Maxime Descoteaux. Compressive Sensing DSI. International Symposium on BIOMEDICAL IMAGING: From Nano to Macro - ISBI HARDI Reconstruction Challenge, Apr 2013, San Francisco, United States. ⟨hal-00908209⟩
Collections
INRIA INRIA2
133 Consultations
0 Téléchargements
