A guided tour of of asynchronous cellular automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Nazim Fatès
Extended version of the Automata'13 paper. Research on asynchronous cellular automata has received a great amount of attention these last years and has turned to a thriving field. We survey the recent research that has been carried out on this topic and present a wide state of the art where computing and modelling issues are both represented.
reviewACA.pdf (190.57 Ko) Télécharger le fichier
hal-00908373 , version 1 (22-11-2013)
hal-00908373 , version 2 (14-01-2014)
hal-00908373 , version 3 (16-01-2014)
hal-00908373 , version 4 (03-06-2014)
hal-00908373 , version 5 (26-08-2014)
  • HAL Id : hal-00908373 , version 1
Nazim Fatès. A guided tour of of asynchronous cellular automata. 2013. ⟨hal-00908373v1⟩
574 Consultations
1851 Téléchargements
