Unified Model for Assessing Checkpointing Protocols at Extreme-Scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Concurrency and Computation: Practice and Experience Année : 2013
George Bosilca
  • Fonction : Auteur
  • PersonId : 863939
Elisabeth Brunet
Jack Dongarra
  • Fonction : Auteur
  • PersonId : 863940
Thomas Herault
  • Fonction : Auteur
  • PersonId : 833735
In this paper, we present a unified model for several well-known checkpoint/restart protocols. The proposed model is generic enough to encompass both extremes of the checkpoint/restart space, from coordinated approaches to a variety of uncoordinated checkpoint strategies (with message logging). We identify a set of crucial parameters, instantiate them and compare the expected efficiency of the fault tolerant protocols, for a given application/platform pair. We then propose a detailed analysis of several scenarios, including some of the most powerful currently available HPC platforms, as well as anticipated Exascale designs. The results of this analytical comparison are corroborated by a comprehensive set of simulations. Altogether, they outline comparative behaviors of checkpoint strategies at very large scale, thereby providing insight that is hardly accessible to direct experimentation.
concurrency-revised.pdf (589.69 Ko) Télécharger le fichier
hal-00908447 , version 1 (23-11-2013)
George Bosilca, Aurélien Bouteiller, Elisabeth Brunet, Franck Cappello, Jack Dongarra, et al.. Unified Model for Assessing Checkpointing Protocols at Extreme-Scale. Concurrency and Computation: Practice and Experience, 2013, 26 (17), pp.2727-2810. ⟨10.1002/cpe.3173⟩. ⟨hal-00908447⟩
551 Consultations
275 Téléchargements
