V. Acary and F. Pérignon, An introduction to SICONOS INRIA, Rhône-Alpes Available online: http://hal.inria.fr/inria-00162911, 2007.
P. Ballard, The Dynamics of Discrete Mechanical Systems with Perfect Unilateral Constraints, Archive for Rational Mechanics and Analysis, vol.154, issue.3, pp.199-274, 2000.
DOI : 10.1007/s002050000105
URL : https://hal.archives-ouvertes.fr/hal-00111308
H. Berghuis and H. Nijmeijer, A passivity approach to controller-observer design for robots, IEEE Transactions on Robotics and Automation, vol.9, issue.6, pp.740-754, 1993.
DOI : 10.1109/70.265918
URL : http://doc.utwente.nl/15045/1/passivity_approach_-_berghuis.pdf
G. Besancon, Global output feedback tracking control for a class of Lagrangian systems, Automatica, vol.38, pp.1915-1921, 2002.
B. Brogliato, Nonsmooth Mechanics, 1999.
DOI : 10.1007/978-1-4471-0557-2
URL : https://hal.archives-ouvertes.fr/hal-01236953
B. Brogliato and W. P. Heemels, Observer Design for Lur'e Systems With Multivalued Mappings: A Passivity Approach, IEEE Transactions on Automatic Control, vol.54, issue.8, pp.1996-2001, 2009.
DOI : 10.1109/TAC.2009.2023968
URL : https://hal.archives-ouvertes.fr/hal-00756302
C. Castaing and M. D. Marques, BV periodic solutions of an evolution problem associated with continuous moving convex sets. Set-Valued Analysis, pp.381-399, 1995.
R. Dzonou, M. D. Monteiro-marques, and L. Paoli, A convergence result for a vibro-impact problem with??a??general inertia operator, Nonlinear Dynamics, vol.2, issue.2, pp.361-384, 2009.
DOI : 10.1007/978-3-0348-7614-8
URL : https://hal.archives-ouvertes.fr/hal-01552482
F. Forni, A. Teel, and L. Zaccarian, Follow the Bouncing Ball: Global Results on Tracking and State Estimation With Impacts, IEEE Transactions on Automatic Control, vol.58, issue.6, pp.1470-1485, 2013.
DOI : 10.1109/TAC.2013.2237952
W. P. Heemels, M. K. Camlibel, J. M. Schumacher, and B. Brogliato, Observer-based control of linear complementarity systems, International Journal of Robust and Nonlinear Control, vol.50, issue.5, pp.1193-1218, 2011.
DOI : 10.1016/0024-3795(83)90062-9
URL : https://hal.archives-ouvertes.fr/hal-00834580
M. Kunze and M. D. Marques, An Introduction to Moreau???s Sweeping Process, Mechanical Systems: Analysis and Modelling, pp.1-60, 2000.
DOI : 10.1007/3-540-45501-9_1
L. Menini and A. Tornambé, Velocity observers for non-linear mechanical systems subject to non-smooth impacts, Automatica, vol.38, issue.12, pp.2169-2175, 2002.
DOI : 10.1016/S0005-1098(02)00164-4
M. D. Marques, Differential Inclusions in Nonsmooth Mechanical Problems: Shocks and Dry Friction, of Progress in Nonlinear Differential Equations and their Applications. Birkhäuser, 1993.
J. J. Moreau, Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications of CISM Courses and Lectures, International Centre for Mechanical Sciences, pp.1-82, 1988.
DOI : 10.1007/978-3-7091-2624-0_1
J. J. Moreau and M. Valadier, A chain rule involving vector functions of bounded variation, Journal of Functional Analysis, vol.74, issue.2, pp.333-345, 1987.
DOI : 10.1016/0022-1236(87)90029-2
S. Nicosia and P. Tomei, Robot control by using only joint position measurements, IEEE Transactions on Automatic Control, vol.35, issue.9, pp.1058-1061, 1990.
DOI : 10.1109/9.58537
J. A. Osorio and J. A. Moreno, Dissipative Design of Observers for Multivalued Nonlinear Systems, Proceedings of the 45th IEEE Conference on Decision and Control, pp.5400-5405, 2006.
DOI : 10.1109/CDC.2006.377335
L. Paoli, A proximal-like method for a class of second order measure-differential inclusions describing vibro-impact problems, Journal of Differential Equations, vol.250, issue.1, pp.476-514, 2011.
DOI : 10.1016/j.jde.2010.10.010
URL : https://hal.archives-ouvertes.fr/hal-01566931
L. Paoli and M. Schatzman, A Numerical Scheme for Impact Problems I: The One-Dimensional Case, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.702-733, 2002.
DOI : 10.1137/S0036142900378728
H. Shim, Y. Son, and J. Seo, Semi-global observer for multi-output nonlinear systems, Systems & Control Letters, vol.42, issue.3, pp.233-244, 2001.
DOI : 10.1016/S0167-6911(00)00098-0
H. Shim and A. Tanwani, Hybrid-type observer design based on a sufficient condition for observability in switched nonlinear systems Nonlinear Control: Special Issue on High Gain Observers and Nonlinear Output Feedback Control Invertibility and Observability of Switched Systems with Inputs and Outputs, Int. J. Robust &, 2012.
A. Tanwani, B. Brogliato, and C. Prieur, Stability and observer design for a class of nonsmooth dynamical systems with nonconvex state constraints
URL : https://hal.archives-ouvertes.fr/hal-00790618
A. Tanwani, H. Shim, and D. Liberzon, Observability for Switched Linear Systems: Characterization and Observer Design, IEEE Transactions on Automatic Control, vol.58, issue.4, pp.891-904, 2013.
DOI : 10.1109/TAC.2012.2224257
A. Tanwani and S. Trenn, Observability of switched differentialalgebraic equations for general switching signals, Proc. 51st IEEE Conf. Decision & Control, pp.2648-2653, 2012.
A. Tanwani and S. Trenn, An observer for switched differentialalgebraic equations based on geometric characterization of observability, Proc. 52nd IEEE Conf. Decision & Control, 2013.
B. Xian, M. S. De-queiroz, D. M. Dawson, and M. L. Mcintyre, A discontinuous output feedback controller and velocity observer for nonlinear mechanical systems, Automatica, vol.40, issue.4, pp.695-700, 2004.
DOI : 10.1016/j.automatica.2003.12.007
