The Stream-based Service-Centered Calculus: a Foundation for Service-Oriented Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Formal Aspects of Computing Année : 2013
We give a formal account of SSCC, a calculus for modeling service-based systems, suitable to describe both service composition (orchestration) and the protocols that services follow when invoked (conversation). The calculus includes primitives for defining and invoking services, for isolating conversations (called sessions) among clients and servers, and for orchestrating services. The calculus is equipped with a reduction and a labeled transition semantics related by an equivalence result. SSCC provides a good trade-off between expressive power for modeling and simplicity for analysis. We assess the expressive power by modeling van der Aalst workflow patterns and an automotive case study from the European project Sensoria. For analysis, we present a simple type system ensuring compatibility of client and service protocols. We also study the behavioral theory of the calculus, highlighting some axioms that capture the behavior of the different primitives. As a final application of the theory, we define and prove correct some program transformations. These allow to start modeling a system from a typical UML Sequence Diagram, and then transform the specification to match the service-oriented programming style, thus simplifying its implementation using web services technology.
Informatique
Fichier non déposé
hal-00909308 , version 1 (26-11-2013)
  • HAL Id : hal-00909308 , version 1
Luís Cruz Filipe, Ivan Lanese, Francisco Martins, António Ravara, Vasco Vasconcelos. The Stream-based Service-Centered Calculus: a Foundation for Service-Oriented Programming. Formal Aspects of Computing, 2013, 60 p. ⟨hal-00909308⟩
Collections
INRIA INRIA2
83 Consultations
0 Téléchargements
