A Conditional Logical Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The Conditional Logical Framework LFK is a variant of the Harper-Honsell-Plotkin's Edinburgh Logical Framemork LF. It features a generalized form of λ-abstraction where β-reductions fire under the condition that the argument satisfies a logical predicate. The key idea is that the type system memorizes under what conditions and where reductions have yet to fire. Different notions of β-reductions corresponding to different predicates can be combined in LFK. The framework LFK subsumes, by simple instantiation, LF (in fact, it is also a sub-system of LF!), as well as a large class of new generalized conditional λ-calculi. These are appropriate to deal smoothly with the side-conditions of both Hilbert and Natural Deduction presentations of Modal Logics. We investigate and characterize the metatheoretical properties of the calculus underpinning LFK, such as subject reduction, confluence, strong normalization.
lpar-08.pdf (160.49 Ko) Télécharger le fichier
hal-00909574 , version 1 (26-11-2013)
Luigi Liquori, Furio Honsell, Marina Lenisa, Ivan Scagnetto. A Conditional Logical Framework. Logic for Programming, Artificial Intelligence, and Reasoning 15th International Conference, LPAR 2008, Doha, Qatar, November 22-27, 2008. Proceedings, Nov 2008, Doha, Qatar. pp.143-157, ⟨10.1007/978-3-540-89439-1_10⟩. ⟨hal-00909574⟩
Collections
INRIA INRIA2
122 Consultations
149 Téléchargements
